GDAL
September 12, 2018, 5:52pm
1
#3644: winGRASS7.7.svn: displaying raster causes: TypeError: environment can only
contain strings
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Default | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: MSWindows 8 |
System Info
GRASS version: 7.7.svn
GRASS SVN revision: r73313
Build date: 2018-09-11
Build platform: x86_64-w64-mingw32
GDAL: 2.2.4
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
Platform: Windows-10-10.0.17134 (OSGeo4W)
loading a raster map to display:
Exception in thread Thread-14:
File "C:\OSGEO4~1\apps\Python27\lib\threading.py", line
801, in __bootstrap_inner
self.run()
File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\co
re\gthread.py", line 99, in run
ret = vars()['callable'](*args, **kwds)
re\render.py", line 405, in _render
p = grass.start_command(cmd[0], env=env,
stderr=grass.PIPE, **cmd[1])
File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\etc\python\gras
s\script\core.py", line 402, in start_command
return Popen(args, **popts)
s\script\core.py", line 76, in __init__
subprocess.Popen.__init__(self, args, **kwargs)
File "C:\OSGEO4~1\apps\Python27\lib\subprocess.py", line
390, in __init__
errread, errwrite)
640, in _execute_child
startupinfo)
TypeError: environment can only contain strings
Ticket URL: <https://trac.osgeo.org/grass/ticket/3644> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
September 13, 2018, 3:38am
2
contain strings
Resolution: | Keywords: Python3
CPU: x86-64 | Platform: MSWindows 8
Changes (by annakrat):
* keywords: => Python3
Ticket URL: <https://trac.osgeo.org/grass/ticket/3644#comment:1> ;
GDAL
September 14, 2018, 7:30pm
3
contain strings
Comment (by annakrat):
Try r73326.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3644#comment:2> ;
GDAL
September 16, 2018, 9:18am
4
contain strings
Comment (by hellik):
Replying to [comment:2 annakrat]:
> Try r73326.
tested with
GRASS SVN revision: r73329
Build date: 2018-09-15
GDAL: 2.2.4
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
works again, thanks. closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3644#comment:3> ;
GDAL
5
contain strings
Type: defect | Status: closed
Resolution: fixed | Keywords: Python3
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3644#comment:4> ;
