[GRASS-dev] [GRASS GIS] #3676: Errors when running r.li.* modules
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: Raster | Version: svn-trunk
Keywords: r.li, landscape | CPU: x86-64
Platform: Linux |
I get different errors when trying to run different r.li.* modules. Here
some examples:
r.li.shannon --overwrite input=landclass96 at PERMANENT
config=forest_mov_win
output=forest_mov_win_sh
munmap_chunk(): invalid pointer
The map is created but cannot be read or displayed:
Failed to run command 'd.rast map=forest_mov_win_sh@user1'. Details:
GRASS_INFO_WARNING(12641,1): LZ4 decompression error
GRASS_INFO_END(12641,1)
GRASS_INFO_ERROR(12641,2): Error uncompressing null data for row 474 of
<forest_mov_win_sh>
GRASS_INFO_END(12641,2)
GRASS 7.7.svn (nc_spm_08_grass7):~ > r.univar forest_mov_win_sh
WARNING: LZ4 decompression error
ERROR: Error uncompressing null data for row 474 of <forest_mov_win_sh>
Further attempts:
r.mapcalc "forest = if(landclass96 == 5, 1, null())"
r.li.edgedensity input=forest config=forest_mov_win output=forest_edge_mw
double free or corruption (!prev) <<<--- THIS
Aborted (core dumped)
... but map is created and no error related to compression.
Instead, if I do something equivalent:
r.li.edgedensity --verbose input=landclass96@PERMANENT
config=forest_mov_win output=forest_edge patch_type=5
munmap_chunk(): invalid pointer <<<--- THIS
r.univar forest_edge
ERROR: Error uncompressing null data for row 474 of <forest_edge>
I attach the config file for reproducibility. And here's the thread in
grass-dev: https://lists.osgeo.org/pipermail/grass-
dev/2018-October/090155.html with Markus' valgrind test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3676&gt;
Resolution: | Keywords: r.li, landscape
       CPU: x86-64 | Platform: Linux
Changes (by veroandreo):
* Attachment "forest_mov_win" added.
config file created with g.gui.rlisetup
Comment (by veroandreo):
Here the results using grass74 relbranch:
GRASS 7.4.2svn (nc_spm_08_grass7):~ > r.li.shannon --overwrite
input=landclass96@PERMANENT config=forest_mov_win output=forest_mov_win_sh
GRASS 7.4.2svn (nc_spm_08_grass7):~ > d.rast forest_mov_win_sh
ERROR: Error uncompressing null data for row 473 of <forest_mov_win_sh>
GRASS 7.4.2svn (nc_spm_08_grass7):~ > r.mapcalc "forest = if(landclass96
== 5, 1, null())" --o
GRASS 7.4.2svn (nc_spm_08_grass7):~ > r.li.edgedensity input=forest
config=forest_mov_win output=forest_edge_mw --o
corrupted size vs. prev_size
config=forest_mov_win output=forest_edge patch_type=5 --o
r.li.edgedensity complete. Raster map <forest_edge> created.
The last one worked... no idea
Ticket URL: <https://trac.osgeo.org/grass/ticket/3676#comment:1&gt;
Comment (by mmetz):
In [changeset:"73488" 73488]:
#!CommitTicketReference repository="" revision="73488"
r.li: fix segfault in r.li.shannon (see #3676)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3676#comment:2&gt;
Comment (by mmetz):
In [changeset:"73489" 73489]:
#!CommitTicketReference repository="" revision="73489"
r.li: fix segfault in r.li.shannon (see #3676, backport trunk r73488)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3676#comment:3&gt;
Comment (by mmetz):
In [changeset:"73490" 73490]:
#!CommitTicketReference repository="" revision="73490"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3676#comment:4&gt;
Comment (by mmetz):
The reason was that excessive rows were written to the output, causing
memory corruption. Valgrind output is now clean for the mentioned test
case and test commands, including the test commands with r.li.edgedensity.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3676#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.li, landscape
* status: new => closed
* resolution: => fixed
Comment:
Tested in trunk and 74 relbranch, no more errors. Thanks! Closing
Ticket URL: <https://trac.osgeo.org/grass/ticket/3676#comment:6&gt;
  Priority: normal | Milestone: 7.4.2
Changes (by martinl):
* milestone: 7.6.0 => 7.4.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3676#comment:7&gt;
