GDAL
October 6, 2018, 4:47pm
1
#3677: v.surf.idw does not respect mask
Reporter: dnix | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Vector | Version: 7.4.1
Keywords: v.surf.idw | CPU: Unspecified
Platform: Unspecified |
Unable to use a mask with v.surf.idw. When mask is set with r.mask, it is
ignored by v.surf.idw and the entire region is interpolated regardless of
the mask.
The documentation notes for v.surf.idw states that a mask may be used to
limit the interpolation area: "If the user has a mask set, then
interpolation is only done for those cells that fall within the mask."
Might this be similar to defect fixed for v.surf.rst in
[https://trac.osgeo.org/grass/ticket/1775 #1775 ]?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3677> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
January 26, 2019, 7:04pm
2
Resolution: | Keywords: v.surf.idw
Comment (by neteler):
The MASK fixes needed in v.surf.rst were: r59737 and r62131.
Maybe the author can check how to apply them here to v.surf.idw?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3677#comment:1> ;
GDAL
January 28, 2019, 3:27am
3
Comment (by annakrat):
I tested it in trunk, for me it is working as expected, mask works. A
reproducible example is needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3677#comment:2> ;
GDAL
May 20, 2022, 3:22am
4
Type: defect | Status: closed
Priority: major | Milestone: 7.8.3
Resolution: fixed | Keywords: v.surf.idw
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Fixed with https://github.com/OSGeo/grass/pull/2383 .
Ticket URL: <https://trac.osgeo.org/grass/ticket/3677#comment:4> ;
