[GRASS-dev] [GRASS GIS] #3688: impossible to start grass from Rstudio in Windows
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.3
Component: Default | Version: 7.4.2
Keywords: | CPU: Unspecified
Platform: MSWindows |
Currently it is impossible to start GRASS from R in Windows (I tested with
GRASS installed from OSGeo4W). It worked perfectly a month ago or so when
Roger Bivand fixed some issues. Apparently it is due to an incompatibility
in dependencies after GRASS was compiled against new GDAL and PROJ.
Here's the R command (paths must be adapted):
initGRASS(gisBase = "C:/OSGeo4W64/apps/grass/grass-7.4.2RC2",
           gisDbase = "C:/Users/RETA/Documents/grassdata",
           location = "nc_spm_08_grass7",
           mapset = "user1",
           SG = "elevation")
The pop-up error is a missing iconv.dll. All locales were in Spanish as
well as the laptop I tested on. After many attempts to try to close the
pop-up error, we got the following in the Rstudio console:
Error in if (!compatible) { : argument is of length zero
In addition: Warning messages:
1: In system(paste("g.dirseps.exe -g", shQuote(Sys.getenv("GISRC"))), :
   running command 'g.dirseps.exe -g "junk"' had status 309
2: In system(paste("g.dirseps.exe -g", shQuote(gisDbase)), intern = TRUE)
   running command 'g.dirseps.exe -g "C:/Users/RETA/Documents/grassdata"'
had status 309
3: In dir.create(loc_path) :
   cannot create dir 'NA\nc_spm_08_grass7', reason 'No such file or
directory'
4: In dir.create(paste(loc_path, "PERMANENT", sep = "/")) :
   cannot create dir 'NA\nc_spm_08_grass7\PERMANENT', reason 'No such file
or directory'
5: In dir.create(paste(loc_path, mapset, sep = "/")) :
   cannot create dir 'NA\nc_spm_08_grass7\user1', reason 'No such file or
directory'
6: In system(paste("g.version", get("addEXE", envir = .GRASS_CACHE), :
   running command 'g.version.exe' had status 309
See mailing list http://osgeo-org.1560.x6.nabble.com/error-when-trying-to-
start-GRASS-from-Rstudio-in-Windows-td5383381.html for further details.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: MSWindows
Changes (by veroandreo):
* Attachment "initGRASS_error_windows.png" added.
Error when trying to start GRASS from Rstudio in Windows - message in
Spanish as mentioned earlier
Comment (by veroandreo):
The pop-up error says: "The code execution cannot continue because
iconv.dll is missing. The problem can be solved re-installing the
software".
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:1&gt;
Comment (by rsbivand):
Can you grab a screen dump of the pop-up? Can you report OSGeo4W component
versions as well as R/rgrass7 versions?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:2&gt;
I do not have the laptop with me now, I can only report back in 10 days or
so that I go back home.
In any case, what's a screen dump? I also attached the screenshot with the
error above if that's what you mean. I just translated the message because
it is in Spanish.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:3&gt;
OK, see it now, sorry. Looks like an OSGeo4W packaging blunder (or path
blunder).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:4&gt;
Comment (by hellik):
Replying to [comment:2 rsbivand]:
component versions as well as R/rgrass7 versions?
System Info
GRASS version: 7.4.2
GRASS SVN revision: r73591
Build date: 2018-10-23
Build platform: x86_64-w64-mingw32
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
Platform: Windows-10-10.0.17134 (OSGeo4W)
> sessionInfo()
R version 3.4.4 (2018-03-15)
Platform: x86_64-w64-mingw32/x64 (64-bit)
Ru
Matrix products: default
locale:
[1] LC_COLLATE=German_Austria.1252 LC_CTYPE=German_Austria.1252
[3] LC_MONETARY=German_Austria.1252 LC_NUMERIC=C
[5] LC_TIME=German_Austria.1252
attached base packages:
[1] stats graphics grDevices utils datasets methods base
other attached packages:
[1] rgrass7_0.1-10 XML_3.98-1.11 sp_1.3-1
loaded via a namespace (and not attached):
[1] compiler_3.4.4 grid_3.4.4 lattice_0.20-35
first missing dll is ''iconv.dll'', then other missing dlls pops up.
step by step adding the missing dlls, a list of them
iconv.dll
proj_5_2.dll
gdal203.dll
geos_c.dll
LIBPQ.dll
ogdi.dll
xerces-c_3_2.dll
expat.dll
jpeg.dll
netcdf.dll
sqlite3.dll
spatialite.dll
all of them are living in ''C:\OSGeo4W64\bin''
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:5&gt;
Replying to [comment:5 hellik]:
>first missing dll is iconv.dll, then other missing dlls pops up.
ok, found it now; started here R/RGUi/RStudio outside of the OSGeo4W-
console, then the dll's are missing.
starting R/RGUi/RStudio from the OSGeo4W-console, then it works.
@Veronica, started your students R/RGUi/RStudio outside of the OSGeo4W-
console?
maybe wiki/manuals should be updated?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:6&gt;
Replying to [comment:6 hellik]:
console?
I think we can close the ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:7&gt;
This is correct, I can replicate that RStudio started by clicking on its
icon, or by clicking on for example an Rmd file, cannot know where OSGeo4W
now keeps its extra dll files. From the latest upgrade of OSGeo4W, you
need to start RStudio from the command line in the OSGeo4W console, say
using "C:/Program Files/RStudio/bin/rstudio.exe" - with the quotation
marks because of the space in the path. The underlying causes are OSGeo4W
arguably messing up path variables, and generally rstudio getting between
the user and file system reality.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:8&gt;
Replying to [comment:8 rsbivand]:
>From the latest upgrade of OSGeo4W, you need to start RStudio from the
command line in the OSGeo4W console, say using "C:/Program
Files/RStudio/bin/rstudio.exe" - with the quotation marks because of the
space in the path.
I don't think that starting Rstudio changed with the latest upgrade of
OSGeo4W.
It's implemented to start RStudio within the winGRASS-standalone-console
as well as in the OSgeo4W-winGRASS-console (within a GRASS session) for
many years now:
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/env.bat.tmpl#L22
22 REM set RStudio temporarily to %PATH% if it exists
23
24 IF EXIST "%ProgramFiles%\RStudio\bin\rstudio.exe" set
PATH=%PATH%;%ProgramFiles%\RStudio\bin
but it isn't yet implemented in the OSGeo4W-console itself to start it
there outside a GRASS session.
OTOH it's implemented now for a year or so to start R/RGui in the OSGeo4W-
console itself outside of a GRASS session by
https://download.osgeo.org/osgeo4w/x86_64/release/grass/grass/setup.hint
sdesc: "GRASS GIS"
ldesc: "Geographic Resources Analysis Support System (GRASS GIS)"
category: Desktop
requires: liblas avce00 gpsbabel gs gdal-python matplotlib msvcrt
msvcrt2012 msvcrt2013 msvcrt2015 iconv libtiff gdal proj pdcurses zlib
fftw libpng python-wx python-numpy python-pil pyopengl cairo psycopg2
rbatch
maintainer: MartinLanda
curr: 7.4.2-1
prev: 7.4.1-3
via rbatch.
if
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:9&gt;
Sorry for the delay, only now I have a windows machine to test... No, my
students did not start R nor RStudio from OSGeo4W Shell (I forgot that
detail).
So, it works, but only if I move to Documents folder, for example. If I
try to start GRASS from R in C disk, I get the following:
> library(rgrass7)
Loading required package: sp
Loading required package: XML
GRASS GIS interface loaded with GRASS version: (GRASS not running)
> initGRASS(gisBase = "C:/OSGeo4W64/apps/grass/grass-7.4.2", gisDbase =
"C:/Users/RETA/Documents/grassdata", location = "nc_spm_08_grass7", mapset
= "user1", SG = "elevation", override=TRUE)
Error in file(file, ifelse(append, "a", "w")) :
   no se puede abrir la conexión
Además: Warning message:
In file(file, ifelse(append, "a", "w")) :
   no fue posible abrir el archivo 'junk': Permission denied
Seems Windows does not grant me permission to write on my own C... how
great :frowning: During the course, the students hit this issue many times.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:10&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords:
* status: new => closed
* resolution: => wontfix
Comment:
Replying to [comment:7 hellik]:
OSGeo4W-console?
Will add this detail to wiki
I´m closing as wontfix since it is indeed impossible to start GRASS from R
in Windows unless one opens R from within OSGeo4W shell and move to a
folder with writing permission. Feel free to modify or reopen
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:11&gt;
