[GRASS-dev] [GRASS GIS] #3699: v.extract: allow random extraction on subsets selected by where, cats and file options [PATCH]
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.8.0
Component: Vector | Version: svn-trunk
Keywords: v.extract random | CPU: Unspecified
Platform: Unspecified |
Currently, v.extract only allows the user to use one of where, cats, file
and random. It can be useful, however, to be able to extract a random
sample of vector features among all those corresponding to certain
criteria, for example based on an attribute. The user can obviously first
run v.extract based on that attribute and then run v.extract again to
select a random sample in the result. However, this can be quite long,
especially if the vector contains many attributes and so those have to be
written at each step.
The applied patch modifies v.extract to allow random sampling even among a
subset defined by the other three options. This would allow running
extractions such as the following (which extracts a random sample of
census blocks amongst those blocks that actually have population in them):
v.extract censusblk_swwake where="TOTAL_POP>0" random=200 out=test
If there are no objections, I will apply this patch to trunk, soon.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3699&gt;
Resolution: | Keywords: v.extract random
Changes (by mlennert):
* Attachment "v_extract_random_with_others.diff" added.
patch to allow random sampling among subsets
