[GRASS-dev] [GRASS GIS] #3718: wingrass: include also unversioned libraries
Reporter: martinl | Owner: grass-dev@…
     Type: task | Status: new
Priority: normal | Milestone: 7.4.4
Component: Packaging | Version: svn-trunk
Keywords: wingrass | CPU: Unspecified
Platform: MSWindows |
Currently WinGRASS builds contain only versioned GRASS libs, eg.
`libgrass_gis.x.y.z.dll`. This makes QGIS GRASS broken in OSGeo4W
framework everytime when a new GRASS point version is released and QGIS
GRASS plugin is still compiled against old point version. WinGRASS could
contain also copy of unversioned libs to avoid such problem (creating
symlinks as done on non-mingw platform cannot work here).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718&gt;
  Reporter: martinl | Owner: martinl
      Type: task | Status: assigned
Resolution: | Keywords: wingrass
       CPU: Unspecified | Platform: MSWindows
Changes (by martinl):
* cc: grass-dev@… (added)
* owner: grass-dev@… => martinl
* status: new => assigned
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:1&gt;
Comment (by martinl):
GRASS 7.7 (trunk) has been modified in r73864 to produce also unversioned
libs on Windows. Can be tested with build no. 357+ from (1) or directly
from OSGeo4W framework (`grass-daily` package).
(1) https://wingrass.fsv.cvut.cz/grass77/x86_64/
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:2&gt;
In [changeset:"73865" 73865]:
#!CommitTicketReference repository="" revision="73865"
remove extra line in Shlib.make, see #3718
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:3&gt;
* Attachment "unversioned-libs.png" added.
Result tested with GRASS 7.7svn.
[[Image(unversioned-libs.png, 400px)]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:4&gt;
Comment (by neteler):
May I release or is anything still open here?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:5&gt;
Replying to [comment:5 neteler]:
yes, still open.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:6&gt;
See related discussion, https://lists.osgeo.org/pipermail/grass-
dev/2018-December/090823.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:7&gt;
Comment (by hellik):
Replying to [comment:7 martinl]:
around 7 years ago there was a thread about versioned/unversioned
dlls/libs in winGRASS, see
https://lists.osgeo.org/pipermail/grass-dev/2010-June/050757.html
see mails before and after.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:8&gt;
Is it acceptable solution? If so I will do backport to g76 a g74
branches ASAP.
what is the reason to backport it to g74?
QGIS 2.18.x reaches its EOL and AFAIU our focus will be on (7.6)/7.8.
it seems there will be a little chance that QGIS 2.18.x/g74 will change.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:9&gt;
  Priority: normal | Milestone: 7.6.0
* milestone: 7.4.4 => 7.6.0
Comment:
Replying to [comment:9 hellik]:
you are right, changing milestone
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:10&gt;
In [changeset:"73905" 73905]:
#!CommitTicketReference repository="" revision="73905"
Shlib.make: MinGW's 'ln' just copies the file, see #3718
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:11&gt;
Replying to [comment:8 hellik]:
my comment
> Should the ctypes wrappers be changed to use the versioned library
> name?
Probably yes, just to avoid having copy of unversioned library names.
sounds nice from GRASS POV. On the other hand would be nice not to break
QGIS GRASS plugin on each GRASS point version :wink:
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:12&gt;
Replying to [comment:12 martinl]:
> my comment
> > name?
it's more about
However: on Windows, the name used to create the DLL (e.g.
libgrass_gis.7.0.svn.dll) is stored in the DLL, and this is preserved
when the file is copied. When linking against a DLL, the name which is
stored in the target (library or executable) is the name stored in the
library, not the name of the file. So linking with -lgrass_gis links
against libgrass_gis.dll, but the resulting executable or library
depends upon libgrass_gis.7.0.svn.dll.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:13&gt;
ah, I see, reverted in r73921
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:14&gt;
Another option would be to remove at least point version from lib names,
see related discussion at https://lists.osgeo.org/pipermail/grass-
dev/2019-January/090920.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:15&gt;
      Type: task | Status: closed
Resolution: wontfix | Keywords: wingrass
* status: assigned => closed
* resolution: => wontfix
Comment:
Closing issue as wontfix, see #3728
Ticket URL: <https://trac.osgeo.org/grass/ticket/3718#comment:16&gt;
