[GRASS-dev] [GRASS GIS] #3740: The GRASS session is "leaking" to the environment
Reporter: pmav99 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Startup | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Linux |
After closing the GRASS GUI the user account's local env is not being
restored. E.g.
$ echo $PATH
/home/pmav99/.local/bin:/usr/local/bin:/usr/local/sbin:/usr/lib/xpra:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
$ which python
/usr/bin/python
$ cat src2/grass/run_gui.sh
#!/usr/bin/env bash
# Run the GRASS GUI, after activating the virtualenv
# the 'dirname readlink' line finds the directory where this script is
located.
# https://stackoverflow.com/questions/59895/getting-the-source-directory-
of-a-bash-script-from-within
GRASS_SRC="$(dirname $(readlink -f $0))"
source "${GRASS_SRC}"/venv/bin/activate
exec "${GRASS_SRC}"/bin.x86_64-pc-linux-gnu/grass77
$ src2/grass/run_gui.sh
Starting GRASS GIS...
Cleaning up temporary files...
Welcome to GRASS GIS 7.7.svn (r74037)
[closing the gui]
$ echo $PATH
/home/pmav99/.local/bin:/home/pmav99/src2/grass/dist.x86_64-pc-linux-
gnu/bin:/home/pmav99/src2/grass/dist.x86_64-pc-linux-
gnu/scripts:/home/pmav99/.grass7/addons/bin:/home/pmav99/.grass7/addons/scripts:/home/pmav99/src2/grass/venv/bin:/home/pmav99/.local/bin:/usr/local/bin:/usr/local/sbin:/usr/lib/xpra:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
$ which python
/home/pmav99/src2/grass/venv/bin/python
As you can see $PATH has changed. Is this by design? Shouldn't the
original session be completely restored?
PS. Sorry if this has been mentioned before, but I couldn't find anything
relevant.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: Linux
Comment (by pmav99):
I checked again, without the `exec` this time and the problem is still
there, so that's not the culprit. Nevertheless, after quitting GRASS (I
made sure that I did not press close GUI button) grass is still running:
pmav99 24041 0.0 0.0 15244 3152 pts/2 S 19:16 0:00 bash
pmav99 24045 0.0 0.1 35200 12480 pts/2 S 19:16 0:00 python
/home/pmav99/src2/grass/bin.x86_64-pc-linux-gnu/grass77
pmav99 24515 0.0 0.0 16792 2064 pts/2 S+ 19:17 0:00 grep
--color=auto grass
PS. In the ticket description, I used the term "closing the GUI". I meant
that I quit GRASS, not that I just closed the GUI and remained with the
text interface, but I can't find how to edit the ticket...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:1&gt;
OK, after writing `exit` on the console, the GRASS session finally exits.
exit
Cleaning up default sqlite database ...
Done.
Goodbye from GRASS GIS
if this is how this is supposed to work, I would suggest changing the
menu/dialog messages, because they are misleading.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:2&gt;
Comment (by mmetz):
Replying to [comment:2 pmav99]:
exits.
The script `run_gui.sh` calls grass77 which establishes a GRASS session on
the command line. The GUI is only started with grass77 --gui, or if the
stored settings indicate that the last time GRASS was started with a GUI.
That means the name `run_gui.sh` is misleading because it establishes a
GRASS session on the command line and maybe starts the GUI, maybe not. In
order to terminate the script grass77 and thus leave the GRASS session,
you need to type `exit` in the command line. This has been standard GRASS
behaviour for decades.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:3&gt;
Replying to [comment:3 mmetz]:
exits.
on the command line. The GUI is only started with grass77 --gui, or if the
I am sorry but I think this is not accurate. Please correct me if I am
wrong, but ''the very first time'' you run the `grass77` executable, you
don't get the CLI, you get the GUI. At least that's what I observe. If you
want to change the behavior you need to call `grass77` with the
`--text/--gtext` argument. So the `--gui` argument is the default one, not
the other way around.
That being said, and I guess that this is the main issue here, the dialog
you get when you press `ctrl+Q` is IMHO confusing. As far as I can tell,
both the `Close GUI` and the `Quit GRASS GIS` button do the exact same
thing, i.e. they return me to the GRASS shell, from which I need to `exit`
in order to return to my regular shell. I could be wrong though. Perhaps
there is some other difference which I don't know about.
Nevertheless, I do find confusing that I have to Quit GRASS twice. Once in
the GUI and once in the console. I would expect that the `Quit GRASS`
button returns me to my own shell. If not, what is the point of having
both that one and the `Close GUI` button?
[[Image(https://i.imgur.com/NlLfc44.png)]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:4&gt;
The relevant code seems to be this (_1):
2599 def _quitGRASS(self):
2600 """Quit GRASS terminal"""
2601 try:
2602 shellPid = int(grass.gisenv()['PID'])
2603 except:
2604 grass.warning(_("Unable to exit GRASS shell: unknown
PID"))
2605 return
2606
2607 Debug.msg(1, "Exiting shell with
pid={0}".format(shellPid))
2608 import signal
2609 os.kill(shellPid, signal.SIGTERM)
The logic of the code that calls `_quitGRASS` seems AFAI can tell correct.
I don't see the warning on the console, so assuming that warnings do get
logged by default, the problem could be in the `os.kill` call. To be
honest, the main reason I was using `exec` in the first place was to have
proper signal propagation (_2). Could someone tell me how can I increase
the log level?
_1:
https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/lmgr/frame.py#L2599
_2: https://unix.stackexchange.com/a/196053/37579
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:5&gt;
Comment (by mmetz):
Replying to [comment:4 pmav99]:
exits.
session on the command line. The GUI is only started with grass77 --gui,
or if the stored settings indicate that the last time GRASS was started
with a GUI.
Here, on Linux, I always get a CLI, and sometimes also a GUI, if I wish to
have one. I don't get a GUI without a CLI.
dialog you get when you press `ctrl+Q` is IMHO confusing. As far as I can
tell, both the `Close GUI` and the `Quit GRASS GIS` button do the exact
same thing, i.e. they return me to the GRASS shell, from which I need to
`exit` in order to return to my regular shell. I could be wrong though.
Perhaps there is some other difference which I don't know about.
When I click the `Quit GRASS GIS` button, both the GUI and the CLI GRASS
session are closed.
in the GUI and once in the console. I would expect that the `Quit GRASS`
This is what happens for me: the `Quit GRASS GIS` button returns me to my
own shell.
Hint: type `exit` in the CLI, this closes the GUI and returns you to your
own shell.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:6&gt;
Replying to [comment:6 mmetz]:
my own shell.
I don't doubt you, but I am afraid this is not the behavior I am observing
though. The complete setup on my end is the following:
1. Create a fresh VM running ubuntu 18.04
2. Check out trunk
3. Compile
Note: In order to avoid the overhead of running Xorg in the VM, I make the
VM headless and connect via SSH. Whenever I need to run a gui application
in the VM I launch an xpra server in the VM: https://xpra.org/
In case someone is not familiar with xpra, it is more or less the
equivalent of X11 forwarding on SSH. I can't say that xpra is definitely
not interfering, but I don't think it is very likely. I will try to test
with plain X11 forwarding to rule that out.
So, when I want to e.g. launch the GRASS GUI, I start an instance of a
terminal emulator (e.g. `terminator`) via xpra. Just to make sure that
everything is clear, the terminal emulator is running on the VM; not on my
laptop. It is being rendered on my laptop's Xorg though. But, at least in
theory this should not be important.
So from within this terminal emulator I launch GRASS using my script. As I
said in a previous message, I did try to launch `grass77` directly from
the emulator's shell (i.e. without the script) but this didn't change
anything. Anyway, while the GRASS GUI is running, the relevant processes
on the VM are:
pmav99 8770 2.7 2.3 1131716 192136 ? Sl 12:02 0:04
/usr/bin/python2 /usr/bin/xpra start --speaker=disabled --start-
child=terminator --microphone=disabled --webcam=disabled --pulseaudio=no
--env=XPR
pmav99 8772 3.1 2.9 1196104 239844 ? Ssl 12:02 0:04 \_
/usr/lib/xorg/Xorg-for-Xpra-S8753 -noreset -novtswitch -nolisten tcp
+extension GLX +extension RANDR +extension RENDER -auth /home/pmav99/.Xau
pmav99 8896 0.3 0.9 1132248 76916 ? Sl 12:02 0:00 \_
/usr/bin/python /usr/bin/terminator
pmav99 8921 0.4 0.0 54412 6684 pts/1 Ss 12:02 0:00 \_
/bin/zsh
pmav99 9094 0.0 0.0 15244 3116 pts/1 S 12:04 0:00
\_ bash src2/grass/run_gui.sh
pmav99 9098 0.1 0.1 35200 12344 pts/1 S 12:04 0:00
\_ python /home/pmav99/src2/grass/bin.x86_64-pc-linux-gnu/grass77
pmav99 9151 0.3 0.0 49808 5980 pts/1 S+ 12:04 0:00
\_ /bin/zsh
pmav99 9152 4.2 2.0 1087160 169400 pts/1 Sl 12:04 0:01
\_ python /home/pmav99/src2/grass/dist.x86_64-pc-linux-
gnu/gui/wxpython/wxgui.py
As you can see, `grass77` starts two child processes ,9151 and 9152. Both
of them are functioning as they should (the process states are S+ and Sl
respectively). Now, when I click on `Quit GRASS GIS`, the GUI closes, but
the shell remains. And this is how the process tree is looking:
pmav99 8770 1.4 2.2 1116340 183864 ? Sl 12:02 0:05
--env=XPR
pmav99 8772 1.3 2.6 1089848 213520 ? Ssl 12:02 0:05 \_
pmav99 8896 0.1 0.9 1132248 76916 ? Sl 12:02 0:00 \_
pmav99 8921 0.1 0.0 54412 6684 pts/1 Ss 12:02 0:00 \_
/bin/zsh
pmav99 9098 0.0 0.1 35200 12344 pts/1 S 12:04 0:00
pmav99 9151 0.0 0.0 49808 5980 pts/1 S+ 12:04 0:00
\_ /bin/zsh
pmav99 9152 0.8 0.0 0 0 pts/1 Z 12:04 0:02
\_ [python] <defunct>
9151 is still running (state `S+`) while 9152 is a zombie process
I would be happy to hear any suggestions to debug this
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:7&gt;
#3740: The "Quit GRASS GIS" button does not close the GRASS shell/session
       CPU: x86-64 | Platform: Linux
Changes (by pmav99):
* cpu: Unspecified => x86-64
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:8&gt;
Comment (by cmbarton):
FWIW, it has always not worked on the Mac. Whether you quit GRASS or quit
the GUI, you still get bumped back to the terminal where you must type
"exit" to end the session.
It would be nice if selecting Quit GRASS actually exited from the GRASS
shell and environment. Barring that, it would be better just to have the
Quit GUI button, with an info box that says "Type 'exit' to quit GRASS
entirely'.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:9&gt;
Just tested this on my main PC: Archlinux + trunk + python 2
When I start the GUI there are two processes, 15369 and 15370:
feanor 2940 0.7 0.4 547480 75700 ? Ssl 18:15 0:53
/usr/bin/python2 /usr/bin/terminator
feanor 2949 0.2 0.0 16336 11116 pts/0 Ss 18:15 0:20 \_
/bin/zsh
feanor 15305 0.5 0.0 21880 14140 pts/0 S 20:16 0:00 \_
python bin.x86_64-pc-linux-gnu/grass77
feanor 15369 3.4 0.0 14316 9416 pts/0 S 20:16 0:00
\_ /bin/zsh
feanor 15370 37.6 0.9 989800 148932 pts/0 Sl 20:16 0:01
\_ python /home/feanor/Prog/svn/grass_svn/dist.x86_64-pc-linux-
When I click `Quit GRASS GIS`, the shell continues to run, while the gui
one becomes a zombie.
feanor 2940 0.7 0.4 547864 76220 ? Ssl 18:15 0:54
/bin/zsh
feanor 15305 0.0 0.0 21880 14140 pts/0 S 20:16 0:00 \_
feanor 15369 0.1 0.0 14316 9420 pts/0 S 20:16 0:00
\_ /bin/zsh
feanor 15370 1.8 0.0 0 0 pts/0 Z 20:16 0:02
Since I remain in the GRASS shell, I can restart the GUI with `g.gui`. If
I do so, a new python process is spawned, which, interestingly enough,
does not belong to the same process tree
feanor 2940 0.7 0.4 548432 76836 ? Ssl 18:15 0:54
/bin/zsh
\_ /bin/zsh
feanor 15370 1.5 0.0 0 0 pts/0 Z 20:16 0:02
feanor 16326 37.8 0.9 989780 148956 pts/0 Sl 20:19 0:01 python
$ pstree -ps 16326
systemd(1)───python(16326)─┬─{python}(16346)
                            ├─{python}(16352)
                            ├─{python}(16353)
                            ├─{python}(16354)
                            └─{python}(16362)
Nevertheless, if I type `exit` in the shell, all processes die as
expected.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:10&gt;
I don't really understand why, but the problem might be related with zsh
after all...
On zsh, which is what I mainly use, I get the problems I mentioned
earlier. On bash though, the button exits GRASS just fine. I tested this
both on the Ubuntu VM and on Archlinux.
Note: If you want to try this, you don't only need to start a zsh shell,
you also need to `export SHELL=/usr/bin/zsh` too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:11&gt;
Comment (by neteler):
Replying to [comment:11 pmav99]:
after all...
Probably something is missing for zsh support in
lib/init/grass.py
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:12&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.8.3
Resolution: fixed | Keywords:
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
Z shell support added in PR:722. Closing as fixed. See also (already
closed) #3009 for the exit issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:14&gt;
