#3841: script/core.py: create_location() fails with FileNotFoundError: [Errno 2]
No such file or directory: '/tmp/grass7-root-94/tmploc/PERMANENT/MYNAME'
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Python | Version: svn-trunk
Keywords: python3, grass.py | CPU: x86-64
Platform: Linux |
In a docker environment (Ubuntu 18:04 based) I get this startup error with
trunk (on a pure Python 3 environment):
# note: the second line from bottom is local debug output via print()
root@6ade79b80a2b:/grassdb# grass --tmp-location EPSG:25832 --exec
g.extension -s extension=i.sentinel url=/src/i.sentinel
Starting GRASS GIS...
Creating new GRASS GIS location <tmploc>...
/tmp/grass7-root-37 tmploc EPSG:25832
ERROR: FileNotFoundError(2, 'No such file or directory')
With Python debugger (pdb) I see that it cannot open a file with
`codecs.open()`:
/tmp/grass7-root-94 tmploc EPSG:25832
25832 None
> /usr/local/bin/grass(853)create_location()
-> gcore.create_location(gisdbase, location,
(Pdb) s
> /usr/local/bin/grass(854)create_location()
-> epsg=epsg, datum_trans=datum_trans)
(Pdb) s
--Call--
/usr/local/grass77/etc/python/grass/script/core.py(1518)create_location()
-> def create_location(dbase, location, epsg=None, proj4=None,
filename=None,
(Pdb) s
/usr/local/grass77/etc/python/grass/script/core.py(1538)create_location()
-> gisdbase = None
(Pdb) s
/usr/local/grass77/etc/python/grass/script/core.py(1539)create_location()
-> if epsg or proj4 or filename or wkt:
(Pdb) s
/usr/local/grass77/etc/python/grass/script/core.py(1541)create_location()
-> gisdbase = gisenv()['GISDBASE']
(Pdb) s
--Call--
> /usr/local/grass77/etc/python/grass/script/core.py(1075)gisenv()
-> def gisenv(env=None):
(Pdb) s
> /usr/local/grass77/etc/python/grass/script/core.py(1086)gisenv()
-> s = read_command("g.gisenv", flags='n', env=env)
(Pdb) s
--Call--
> /usr/local/grass77/etc/python/grass/script/core.py(491)read_command()
-> def read_command(*args, **kwargs):
(Pdb) s
> /usr/local/grass77/etc/python/grass/script/core.py(500)read_command()
-> encoding = 'default'
(Pdb) s
> /usr/local/grass77/etc/python/grass/script/core.py(501)read_command()
-> if 'encoding' in kwargs:
(Pdb) s
> /usr/local/grass77/etc/python/grass/script/core.py(504)read_command()
-> if _capture_stderr and 'stderr' not in kwargs.keys():
(Pdb) s
> /usr/local/grass77/etc/python/grass/script/core.py(506)read_command()
-> process = pipe_command(*args, **kwargs)
> /usr/local/grass77/etc/python/grass/script/core.py(512)read_command()
-> if _capture_stderr and returncode:
(Pdb) n
> /usr/local/grass77/etc/python/grass/script/core.py(514)read_command()
-> return handle_errors(returncode, stdout, args, kwargs)
(Pdb) n
--Return--
/usr/local/grass77/etc/python/grass/script/core.py(514)read_command()->'GISDBASE=/gr...T=<UNKNOWN>\n'
(Pdb) n
> /usr/local/grass77/etc/python/grass/script/core.py(1087)gisenv()
-> return parse_key_val(s)
(Pdb) n
--Return--
/usr/local/grass77/etc/python/grass/script/core.py(1087)gisenv()->{'GISDBASE':
...: '<UNKNOWN>'}
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1542)create_location()
-> run_command('g.gisenv', set='GISDBASE=%s' % dbase)
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1544)create_location()
-> if not os.path.exists(dbase):
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1548)create_location()
-> if os.path.exists(os.path.join(dbase, location)):
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1556)create_location()
-> kwargs = dict()
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1557)create_location()
-> if datum:
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1559)create_location()
-> if datum_trans:
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1562)create_location()
-> if epsg:
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1563)create_location()
-> ps = pipe_command('g.proj', quiet=True, flags='t', epsg=epsg,
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1564)create_location()
-> location=location, stderr=PIPE, **kwargs)
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1577)create_location()
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1578)create_location()
-> error = ps.communicate()[1]
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1579)create_location()
-> run_command('g.gisenv', set='GISDBASE=%s' % gisdbase)
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1581)create_location()
-> if ps.returncode != 0 and error:
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1584)create_location()
-> try:
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1585)create_location()
-> fd = codecs.open(os.path.join(dbase, location, 'PERMANENT', 'MYNAME'),
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1586)create_location()
-> encoding='utf-8', mode='w')
(Pdb) n
FileNotFoundError: [Errno 2] No such file or directory:
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1592)create_location()
-> except OSError as e:
(Pdb) n
/usr/local/grass77/etc/python/grass/script/core.py(1593)create_location()
-> raise ScriptError(repr(e))
(Pdb) n
grass.exceptions.ScriptError: FileNotFoundError(2, 'No such file or
directory')
(Pdb) n
--Return--
/usr/local/grass77/etc/python/grass/script/core.py(1593)create_location()->None
(Pdb) n
directory')
(Pdb) n
> /usr/local/bin/grass(864)create_location()
-> except gcore.ScriptError as err:
(Pdb) n
> /usr/local/bin/grass(865)create_location()
-> fatal(err.value.strip('"').strip("'").replace('\\n', os.linesep))
(Pdb) n
SystemExit: Exiting...
(Pdb) n
--Return--
> /usr/local/bin/grass(865)create_location()->None
The code in question:
https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/script/core.py#L1573
1573 try:
1574 fd = codecs.open(os.path.join(dbase, location,
1575 encoding='utf-8', mode='w')
1576 if desc:
1577 fd.write(desc + os.linesep)
1578 else:
1579 fd.write(os.linesep)
1580 fd.close()
1581 except OSError as e:
1582 raise ScriptError(repr(e))
Version used:
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.2 LTS
Release: 18.04
Codename: bionic
python3 --version
Python 3.6.7
Any ideas here?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3841>
