#3852: PyGRASS GridModule silently ignores when module has no output defined
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: PyGRASS | Version: unspecified
Keywords: GridModule | CPU: Unspecified
Platform: Unspecified |
For modules like G7:r.mapcalc PyGRASS !GridModule class fails to work. No
output is patched since the module has no output option defined.
from grass.pygrass.modules import Module
from grass.pygrass.modules.grid import GridModule
from grass.pygrass.utils import findmaps
from grass.pygrass.gis import Mapset
Module('g.region', n=1000, s=0, e=1000, w=0, res=1)
grd = GridModule('r.mapcalc',
width=250, height=250, overlap=0,
processes=4, split=False,
expression='out = 1')
grd.run()
print (findmaps('raster', 'out', mapset=str(Mapset())))
Prints
100%
100%
100%
100%
100%
100%
100%
100%
100%
100%
100%
100%
100%
100%
100%
100%
-> no raster map created. The !GridModule should fail at least when no
output option is defined.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3852>
