[GRASS-dev] [GRASS GIS] #3891: t.rast.algebra: if clause with two conditions does not work properly
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Temporal | Version: unspecified
Keywords: t.rast.algebra, r.mapcalc | CPU: Unspecified
Platform: Unspecified |
I have a daily lst time series that I converted to celsius degrees. I want
to count how many days per year have LST >= 20 and <= 30. So, I first do
the following:
t.rast.algebra expression="tmean_higher20_lower30 = if(lst_daily_celsius
>= 20.0 && lst_daily_celsius <= 30.0, lst_daily_celsius, null())"
basename=tmean_higher20_lower30 suffix=gran nprocs=7
with the intention of using t.rast.aggregate afterwards.
However, without any error, the `t.rast.algebra` command produces either
an empty STRDS or one full of null maps if I use the -n flag.
If I run the corresponding `r.mapcalc` command for a single date, it works
as expected. Region is properly set, input maps have values in the proper
range. No idea what's wrong. I have used this command before and it worked
just fine. It is indeed something very simple for t.rast.algebra.
The only odd thing I see when I do a dry run is how it builds the
r.mapcalc command, that in the second part of the condition it puts
parenthesis, but I don't know much python as to judge that.
['EQUAL'] False False False True && & False False False
lst_2014_01_01@italy_LST_1km_daily_reconstructed_daily >=
20.0&&(lst_2014_01_01@italy_LST_1km_daily_reconstructed_daily <= 30.0)
lst_2014_01_02@italy_LST_1km_daily_reconstructed_daily >=
20.0&&(lst_2014_01_02@italy_LST_1km_daily_reconstructed_daily <= 30.0)
[rest skipped]
lst_2018_12_31@italy_LST_1km_daily_reconstructed_daily >=
20.0&&(lst_2018_12_31@italy_LST_1km_daily_reconstructed_daily <= 30.0)
build_condition_cmd_list ['EQUAL']
['EQUAL'] False False False False None None False False False
{'STDS': {'name': 'tmean_higher20_lower30',
           'stdstype': 'strds',
           'temporal_type': 'absolute'},
  'processes': [{'flags': ['overwrite'],
                 'inputs': [('expression',
'tmean_higher20_lower30_2014_01_01=if(lst_2014_01_01@italy_LST_1km_daily_reconstructed_daily
'20.0&&(lst_2014_01_01@italy_LST_1km_daily_reconstructed_daily '
                             '<= 30.0), '
'lst_2014_01_01@italy_LST_1km_daily_reconstructed_daily, '
                             'null())'),
                            ('region', 'current')],
                 'name': 'r.mapcalc',
                 'outputs': },
[rest skipped]
  'register': [('tmean_higher20_lower30_2014_01_01',
                '2014-01-01 00:00:00',
                '2014-01-02 00:00:00'),
               ('tmean_higher20_lower30_2014_01_02',
                '2014-01-02 00:00:00',
                '2014-01-03 00:00:00'),
[rest skipped]
               ('tmean_higher20_lower30_2018_12_31',
                '2018-12-31 00:00:00',
                '2019-01-01 00:00:00')],
  'remove': }
I attach the full output of the dry run.
I tested with python2 and python3, same behavior. I use grass-dev in
Fedora 30.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3891&gt;
Resolution: | Keywords: t.rast.algebra, r.mapcalc
Comment (by veroandreo):
full dry run output is bigger than allowed... I hope the snippets copied
above are enough...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3891#comment:1&gt;
Ok, this is odd... If I replace the former command, with the following:
t.rast.algebra -n expression="tmean_higher20_lower30 =
if(lst_daily_celsius >= 20.0 && lst_daily_celsius <= 30.0, 1, null())"
basename=tmean_higher20_lower30 suffix=gran nprocs=7 --o
i.e., putting 1 instead of leaving the value that the map has, all works
fine... why does it fail to keep the value that was there originally if it
meets the condition???
Ticket URL: <https://trac.osgeo.org/grass/ticket/3891#comment:2&gt;
