[GRASS-dev] [GRASS GIS] #3925: v.report - UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.8.1
Component: Vector | Version: git-releasebranch78
Keywords: python3, py3, wingrass | CPU: x86-64
Platform: MSWindows |
tested with
GRASS Version: 7.8.1dev
Code revision: d1c4ad132
Build date: 2019-10-22
Build platform: x86_64-w64-mingw32
GDAL: 2.4.1
PROJ: 5.2.0
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.3
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
downloaded data from geonames.org and imported data by v.in.geonames
v.report map=at_out@data option=coor
   File "C:\OSGEO4~1\apps\grass\grass78/scripts/v.report.py",
line 226, in <module>
     main()
line 108, in main
     cols = decode(line).rstrip('\r\n').split('|')
   File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\scri
pt\utils.py", line 193, in decode
     return bytes_.decode(enc)
   File "C:\OSGEO4~1\apps\Python37\lib\encodings\cp1252.py",
line 15, in decode
     return
codecs.charmap_decode(input,errors,decoding_table)
in position 195: character maps to <undefined>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925&gt;
#3925: winGRASS 7.8.1dev: 'charmap' codec can't decode byte 0x9d - issue in vector
attribute data handling (e.g. opening attribute table, v.report, etc)
  Priority: blocker | Milestone: 7.8.1
Resolution: | Keywords: python3, py3, wingrass
       CPU: x86-64 | Platform: MSWindows
Changes (by hellik):
* priority: major => blocker
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:1&gt;
Comment (by hellik):
now tested in a windows 10 box with a german locale:
Code revision: f5bfe545c
Build date: 2019-10-27
GDAL: 2.4.1
PROJ: 5.2.0
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.3
download geonames data of an
[http://download.geonames.org/export/dump/AT.zip AT dump]
v.in.geonames input=D:\temp\geonames\AT\AT.txt output=at_geonames
Converting 51999 place names...
Scanne die Eingabe zur Ermittelung der Spaltentypen...
Number of columns: 19
Number of rows: 51999
WARNING: Spalte Nummer 13 <admin3code> ist als string definiert und hat
nur Integer-Werte.
WARNING: Spalte Nummer 14 <admin4code> ist als string definiert und hat
nur Integer-Werte.
Importiere Punkte...
Fülle Tabelle...
Erstelle Topologie für die Vektorkarte <at_geonames@data>...
Registriere Primitive...
GRASS_INFO_PROGRESS: 10000
GRASS_INFO_PROGRESS: 20000
GRASS_INFO_PROGRESS: 30000
GRASS_INFO_PROGRESS: 40000
GRASS_INFO_PROGRESS: 50000
clicking on a point with a german umlaut
east, north: 11.31700474110463, 47.23295282435024
at_geonames@data:
   Type: Point
   Layer: 1
   Category: 10136
   Driver: sqlite
   Database: D:\grassdata\loc_test_vingeonames\data\sqlite\sqlite.db
   Table: at_geonames
   Key_column: cat
   Attributes:
     cat: 10136
     geonameid: 2762446
     asciiname: Vellenberg
     latitude: 47.23333
     longitude: 11.31667
     featureclass: S
     featurecode: FRM
     countrycode: AT
     admin1code: 07
     admin2code: 703
     admin3code: 70312
     population: 0
     gtopo30: 865
     timezone: Europe/Vienna
     modification: 2014-05-03
at_geonames@data:
   Type: Point
   Layer: 1
   Category: 25781
   Driver: sqlite
   Table: at_geonames
   Key_column: cat
   Attributes:
     cat: 25781
     geonameid: 2778215
     asciiname: Goetznerberg
     latitude: 47.23333
     longitude: 11.31667
     featureclass: S
     featurecode: FRM
     countrycode: AT
     admin1code: 07
     admin2code: 703
     admin3code: 70312
     population: 0
     gtopo30: 865
trying v.report
v.report map=at_geonames@data option=coor
     main()
line 108, in main
line 15, in decode
     return
or trying to open the vector attribute table
   File
"C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\frame.py",
line 2060, in OnShowAttributeTable
selection=selection)
   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\dbmgr\ma
nager.py", line 112, in __init__
self.CreateDbMgrPage(parent=self, pageName='browse')
   File
"C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\dbmgr\base.py",
line 811, in CreateDbMgrPage
parent=parent, parentDbMgrBase=self, onlyLayer=onlyLayer)
   File
line 1095, in __init__
self.AddLayer(layer)
   File
line 1138, in AddLayer
self.dbMgrData, layer, self.pages)
   File
line 113, in __init__
keyColumn = self.LoadData(layer)
   File
line 278, in LoadData
record = decode(outFile.readline().strip()).replace('\n',
line 15, in decode
return codecs.charmap_decode(input,errors,decoding_table)
UnicodeDecodeError
'charmap' codec can't decode byte 0x9d in position 219:
opening the table freezes the attribute table window
it seems to be an encoding issue of attribute data handling
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:2&gt;
maybe related #3220 WinGRASS not recognizing accented utf-8 (nor cp1252)
attribute values
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:3&gt;
v.db.select output of the geonames data:
v.db.select map=at_geonames@data
cat|geonameid|name|asciiname|alternatename|latitude|longitude|featureclass|featurecode|countrycode|cc2|admin1code|admin2code|admin3code|admin4code|population|elevation|gtopo30|timezone|modification
1|2598245|Sandgatterl|Sandgatterl||47.75|14.56667|T|PASS|AT||04|415|41522||0||1490|Europe/Vienna|2014-05-02
2|2598246|Viehtalalm|Viehtalalm||47.75|14.56667|L|GRAZ|AT||04||||0||1490|Europe/Vienna|1999-04-30
3|2598247|Adlmoarstein|Adlmoarstein||47.75|14.55|T|CLF|AT||04||||0||1023|Europe/Vienna|1999-04-30
4|2598248|Waldbaueralm|Waldbaueralm||47.75|14.56667|L|GRAZ|AT||04||||0||1490|Europe/Vienna|1999-04-30
5|2598249|Federeck|Federeck||47.75|14.56667|T|PK|AT||04|415|41522||0||1490|Europe/Vienna|2014-05-02
6|2598250|Mooshöhe|Mooshoehe||47.75|14.55|P|PPL|AT||04|415|41522||0||1023|Europe/Vienna|2014-05-02
7|2598251|Antonihütte|Antonihuette||47.75|14.53333|S|HUT|AT||04|415|41522||0||866|Europe/Vienna|2014-05-02
8|2598252|Bergeralm|Bergeralm||47.75|14.51667|L|GRAZ|AT||04||||0||780|Europe/Vienna|1999-04-30
9|2598253|Blabergalm|Blabergalm||47.75|14.5|L|GRAZ|AT||04||||0||885|Europe/Vienna|1999-04-30
10|2598254|Nattereck|Nattereck||47.75|14.48333|T|PK|AT||04|409|40914||0||721|Europe/Vienna|2014-05-02
11|2598255|Langeck|Langeck||47.75|14.48333|T|PK|AT||04|409|40914||0||721|Europe/Vienna|2014-05-02
12|2598256|Zorngraben|Zorngraben||47.75|14.46667|H|STMI|AT||04||||0||951|Europe/Vienna|1999-04-30
13|2598257|Gugler|Gugler||47.75|14.45|T|PK|AT||04|409|40914||0||1019|Europe/Vienna|2014-05-02
14|2598258|Zorngrabenklause|Zorngrabenklause||47.75|14.45|T|SLP|AT||04||||0||1019|Europe/Vienna|1999-04-30
15|2598259|Sitzenbacher Klause|Sitzenbacher
Klause||47.75|14.45|T|PK|AT||04|409|40914||0||1019|Europe/Vienna|2014-05-02
16|2598260|Sitzenbachhütte|Sitzenbachhuette||47.75|14.45|S|HUT|AT||04|409|40914||0||1019|Europe/Vienna|2014-05-02
17|2598261|Deckleitnerbach|Deckleitnerbach||47.75|14.45|H|STM|AT||04||||0||1019|Europe/Vienna|1999-04-30
18|2598262|Hundseck|Hundseck||47.75|14.41667|T|PK|AT||04|409|40914||0||1120|Europe/Vienna|2014-05-02
19|2598263|Schafgraben|Schafgraben||47.75|14.4|H|STMI|AT||04||||0||1081|Europe/Vienna|1999-04-30
20|2598264|Maierreut|Maierreut||47.75|14.4|L|GRAZ|AT||04||||0||1081|Europe/Vienna|1999-04-30
21|2598265|Rumpelmayrreut|Rumpelmayrreut||47.75|14.38333|L|GRAZ|AT||04||||0||1094|Europe/Vienna|1999-04-30
22|2598266|Bloßboden|Blossboden||47.75|14.36667|T|SLP|AT||04||||0||1439|Europe/Vienna|1999-04-30
23|2598267|Weiße Ries|Weisse
Ries||47.75|14.36667|T|CLF|AT||04||||0||1439|Europe/Vienna|1999-04-30
v.db.select seems to work, but some encoding issues also there, e.g.
**Weiße Ries|Weisse Ries**
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:4&gt;
Replying to [comment:4 hellik]:
starting v.db.select pops up the same encoding error:
Exception in thread Thread-20:
   File "C:\OSGEO4~1\apps\Python37\lib\threading.py", line
917, in _bootstrap_inner
     self.run()
   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\core\gco
nsole.py", line 162, in run
     self.resultQ.put((requestId, self.requestCmd.run()))
   File
"C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\core\gcmd.py",
line 606, in run
     self._redirect_stream()
   File
line 631, in _redirect_stream
     line = recv_some(self.module, e=0, stderr=0)
   File
line 335, in recv_some
     y.append(decode(r))
line 15, in decode
     return
in position 840: character maps to <undefined>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:5&gt;
Comment (by annakrat):
This is a larger problem. In case of geonames, they are encoded in utf8,
but the decode function uses local encoding. There is GRASS_DB_ENCODING,
which should in theory help, but it's not used in v.report and more
generally, it's not tied to individual tables and it's not user-friendly.
One practical way, which wouldn't solve this for all cases, but perhaps
majority is to have a new decode function for attribute data, which would
try first GRASS_DB_ENCODING if specified, then try decoding with local
encoding and if that doesn't work, use utf8.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:6&gt;
Comment (by neteler):
Replying to [comment:6 annakrat]:
Conditional GRASS_DB_ENCODING which might be used for inspiration in this
regards:
https://github.com/OSGeo/grass/blob/b5b00f972917e38a6a912f7c385ddbf791889e70/gui/wxpython/dbmgr/base.py#L971
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:7&gt;
Replying to [comment:7 neteler]:
this regards:
Based on this if you don't have DB encoding specified (in GUI preferences
or through env variable) then it uses utf-8. That's fine on systems with
utf-8 but on Windows? Should it use local encoding instead? Since we need
to work with Python 3 and unicode strings, the garbage in, garbage out
doesn't work now and at the same time we don't know the encoding of the
attributes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:8&gt;
  Priority: blocker | Milestone: 7.8.3
Comment (by mmetz):
Replying to [comment:5 hellik]:
This was apparently running v.db.select on the command line, not in the
GRASS python console.
> self.run()
This was apparently running v.db.select using the GUI.
Maybe the decoding must be adjusted according to the input.
If input is the output of a GRASS db query, the same encoding needs to be
used that is used in the GRASS db.
If input is provided by the user, the system's
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:12&gt;
Comment (by martinl):
Is it really a blocker?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:13&gt;
  Priority: major | Milestone: 7.8.3
Changes (by annakrat):
* priority: blocker => major
Comment:
There has been some fixes in GUI, which could help a little bit. The
general problem persists, but I don't think it's blocker.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:14&gt;
