[GRASS-dev] [GRASS GIS] #394: v.mkgrid: lines not areas
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Priority: minor | Milestone: 6.4.0
Component: Vector | Version: unspecified
Keywords: v.mkgrid | Platform: Unspecified
      Cpu: Unspecified |
Nice to see the new -p points mode for v.mkgrid to save the v.extract
centroids + v.type step.
It would also be nice to have a -l flag to create the grid as lines
to save the v.extract boundary + v.type step. These are nice to create in
a wgs84 lat/lon location and then v.proj into a projected location.
'd.grid -w' does this, but it's nice e.g. for a shapefile
you can use as an overlay in QGIS.
or get rid of the flags and have a type=area,points,lines option.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/394&gt;
  Priority: minor | Milestone: 6.5.0
Resolution: | Keywords: v.mkgrid
  Platform: All | Cpu: All
Changes (by hamish):
  * platform: Unspecified => All
  * cpu: Unspecified => All
  * milestone: 6.4.0 => 6.5.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/394#comment:1&gt;
Comment (by hamish):
Replying to [ticket:394 hamish]:
> lines to save the v.extract boundary + v.type step.
(v.category step also needed)
also all segments of those grid lines should share a common cat, and that
cat be linked to attribute columns ??_str and ??_dbl with nicely formatted
& raw ordinate value.
[ G_format_easting(), G_format_northing() ]
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/394#comment:2&gt;
Reporter: hamish | Owner: grass-dev@…
Component: Vector | Version: svn-releasebranch70
Keywords: v.mkgrid | Platform: All
      Cpu: All |
Changes (by neteler):
  * priority: minor => normal
  * version: unspecified => svn-releasebranch70
  * milestone: 6.5.0 => 7.0.0
Comment:
The option to generate lines instead of areas (new -l flag) would be
highly welcome.
Ticket URL: <http://trac.osgeo.org/grass/ticket/394#comment:3&gt;
      Cpu: All |
Comment(by lucadelu):
Replying to [comment:3 neteler]:
highly welcome.
Please check and try r61519.
If it works should be backported?
Ticket URL: <http://trac.osgeo.org/grass/ticket/394#comment:4&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: v.mkgrid
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:4 lucadelu]:
highly welcome.
Thanks, works fine. Backported in r61643, closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/394#comment:5&gt;
