[GRASS-dev] [GRASS GIS] #3957: Clicking Help on first screen does nothing
Reporter: jidanni | Owner: grass-dev@…
     Type: defect | Status: new
Priority: trivial | Milestone:
Component: Startup | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
It's the user's very first use...
$ grass
Then click Help. Nothing happens.
Some error message should appear somewhere.
Maybe this help button should be greyed out unless the current screen is
doing a action that has a help page.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3957&gt;
  Priority: trivial | Milestone: 7.8.2
Component: Startup | Version: git-releasebranch78
Resolution: | Keywords: help
Changes (by neteler):
* keywords: => help
* version: unspecified => git-releasebranch78
* milestone: => 7.8.2
Comment:
Replying to [ticket:3957 jidanni]:
> $ grass
That's unexpected. It should open a browser and therein the helptext.html.
It respects the env variable `GRASS_HTML_BROWSER` and, if undefined, it
searches for numerous candidates:
  * see https://github.com/OSGeo/grass/blob/master/lib/init/grass.py#L678
Maybe your's is missing?
The question is: which operating system do you use? And: is any web
browser installed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3957#comment:1&gt;
Comment (by jidanni):
OK, today it is working.
Standard Debian sid install. BROWSER=chromium.
Maybe it is now working because I have initialized the databases, etc.
However a vanilla
# su - some_vanilla_account
$ DISPLAY=:0 grass
BROWSER=chromium DISPLAY=:0 grass
Starting GRASS GIS...
(gis_set.py:16417): dbind-WARNING **: 01:53:33.208: Couldn't register with
accessibility bus: Did not receive a reply. Possible causes include: the
remote application did not send a reply, the message bus security policy
blocked the reply, the reply timeout expired, or the network connection
was broken.
and then clicking Help does nothing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3957#comment:2&gt;
Same with
$ GRASS_HTML_BROWSER=lynx DISPLAY=:0 grass
$ GRASS_HTML_BROWSER=chromium DISPLAY=:0 grass
Ticket URL: <https://trac.osgeo.org/grass/ticket/3957#comment:3&gt;
Comment (by neteler):
Probably you have to `export` the variables?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3957#comment:4&gt;
Resolution: | Keywords: help, Debian
       CPU: Unspecified | Platform: Linux
* keywords: help => help, Debian
* platform: Unspecified => Linux
Ticket URL: <https://trac.osgeo.org/grass/ticket/3957#comment:5&gt;
Putting them on the command line exports them.
$ a=b set|grep a=b
$ a=b env|grep a=b
a=b
Ticket URL: <https://trac.osgeo.org/grass/ticket/3957#comment:6&gt;
I guess, in your case, it is more related to #3964
Ticket URL: <https://trac.osgeo.org/grass/ticket/3957#comment:7&gt;
  Priority: trivial | Milestone: 7.8.3
Comment (by wenzeslaus):
If you have `xdg-open` available, this should just work. It's the default
in `grass.py` for all systems except Windows and macOS.
I'm getting some strange behavior when I actually set the variable:
GRASS_HTML_BROWSER=firefox grass
GRASS_HTML_BROWSER=chromium grass
However, in that case, not even g.manual is working. Anybody else
observing this? If yes, can you just open a new issue on !GitHub for that?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3957#comment:10&gt;
