[GRASS-dev] [GRASS GIS] #3960: v.to.points: clarify user is not able to control where points end up
Reporter: jidanni | Owner: grass-dev@…
Priority: trivial | Milestone:
Component: Docs | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
In man v.to.points at
  "The dmax parameter is the maximum limit but not an exact distance."
then do mention
  "A complicated internal algorithm is used to place points at certain
points best representing the line."
before saying
  "To place points with exact distance from the beginning of the vector
line the user should use v.segment."
That way the user would finally understand that he is not able to control
the exact distances where points end up, and stop trying. In fact it would
be good to say that to!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3960&gt;
