GDAL
January 21, 2020, 10:54am
1
#4022: impossible to remove vect and delete attribute from gui
Reporter: 1266 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Linux |
I cannot remove vector object and/or attribute data from the right-clic
menu on attribute box in the gui (delete selected records/features) with
grass 7.8 or 7.9 (on debian buster with 'fr' or 'en' locale)
But "v.edit tool=delete map=mymap where="mycolum=myvalue" and db.execute
"sql=DELETE FROM mymap WHERE mycolomn = myvalue" work fine.
console return :
File "/usr/local/grass78/gui/wxpython/dbmgr/base.py", line
1997, in OnDeleteSelected
if self.OnDataItemDelete(None) and self.mapdisplay:
1748, in OnDataItemDelete
self.ApplyCommands(self.listOfCommands,
self.listOfSQLStatements)
982, in ApplyCommands
sqlFile.write(sql.encode('utf-8') + ';')
TypeError
can't concat str to bytes
Ticket URL: <https://trac.osgeo.org/grass/ticket/4022> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
January 21, 2020, 6:06pm
2
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by hellik):
Confirmed with the latest winGRASS master daily builds
Ticket URL: <https://trac.osgeo.org/grass/ticket/4022#comment:1> ;
GDAL
January 21, 2020, 6:08pm
3
Component: Python | Version: git-releasebranch78
Resolution: | Keywords: Py3, Python 3
Changes (by hellik):
* keywords: => Py3, Python 3
* version: unspecified => git-releasebranch78
* component: Default => Python
Ticket URL: <https://trac.osgeo.org/grass/ticket/4022#comment:2> ;
GDAL
February 15, 2020, 9:02pm
4
Comment (by neteler):
See https://github.com/OSGeo/grass/pull/344 by Anna @petrasovaa
Ticket URL: <https://trac.osgeo.org/grass/ticket/4022#comment:3> ;
GDAL
February 19, 2020, 4:14am
5
Comment (by annakrat):
Changes are now in master available for testing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/4022#comment:4> ;
GDAL
February 21, 2020, 8:12pm
6
tested with
GRASS Version: 7.9.dev
Code revision: ac8bd2777
Build date: 2020-01-20
Build platform: x86_64-w64-mingw32
GDAL: 3.0.4
PROJ: 6.3.1
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
seems to work.
closing ticket?
Ticket URL: <https://trac.osgeo.org/grass/ticket/4022#comment:5> ;
GDAL
February 21, 2020, 11:10pm
7
Replying to [comment:5 hellik]:
> tested with
> GDAL: 3.0.4
> PROJ: 6.3.1
> GEOS: 3.8.0
> SQLite: 3.29.0
> Python: 3.7.0
> wxPython: 4.0.7
> seems to work.
> closing ticket?
backporting before closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/4022#comment:6> ;
GDAL
February 29, 2020, 2:55am
8
Type: defect | Status: closed
Resolution: fixed | Keywords: Py3, Python 3
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Merged to 78.
Ticket URL: <https://trac.osgeo.org/grass/ticket/4022#comment:7> ;
