#4023: TypeError: a bytes-like object is required, not 'str'
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: MSWindows |
Running the addon r.diversity on grass 7.9 (Windows 10), I get the
following error:
C:\Users\hsc\Documents\GRASSGIS\scripts\r.diversity.py --overwrite
input=landschap@datamodel prefix=renyi3 alpha=0.6 method=renyi
File
"C:\Users\hsc\Documents\GRASSGIS\scripts\r.diversity.py",
line 283, in <module>
sys.exit(main())
File
line 149, in main
quiet, overwrite)
File
line 160, in calculateM
createConfFile(r, map_in, home)
File
line 240, in createConfFile
fileConf.writelines(outputLine)
(Wed Jan 22 12:02:17 2020) Command finished (3 sec)
I guess something to do with Python2 vs Python 3 (using the latter), but I
can't pin it down.
