[GRASS-dev] [GRASS GIS] #407: Can not set vector layer properties
Reporter: jachym | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-32 |
When I want to add new vector layer to map display, it appears in the GIS
Manager window, but none window pops up, where I could choose new layers
name (and mapset) (d.vect window, I guess). For rasters, this works. The
new vector layer is called "vector map (doubleclick to change
properties)".
The problem appears ONLY, when LANG set to something different from "C" (I
use cs_CZ.UTF8 - I did not tested other languages). When LANG=C and g.gui
gui=wxpython&, everything works like a charm.
Tested with new 6.4. branch.
Ticket URL: <http://trac.osgeo.org/grass/ticket/407&gt;
  Reporter: jachym | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords:
  Platform: Linux | Cpu: x86-32
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Should be fixed in r34974 (devbr6) r34975 (trunk) and r34976 (relbr64).
Ticket URL: <http://trac.osgeo.org/grass/ticket/407#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/407#comment:2&gt;
