GDAL
1
#54: g.remove mixes raster and vector maps: "Remove reclassed map first"
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: |
A strange bug appeared: Trying to remove a vector map, g.remove gets
confused with a non-exiting reclass map
GRASS 6.3.svn (pat):~ > g.remove
vect=lst_20050101_avg,lst_20050101_avg2,lst_200501_avg_filt
WARNING: [lst_20050101_avg@modisLSTzanzara] is a base map. Remove
reclassed
map first: MASK@modisLSTzanzara
Removing vector <lst_20050101_avg2>
WARNING: [lst_200501_avg_filt@modisLSTzanzara] is a base map. Remove
reclassed map first: MASK@modisLSTzanzara
GRASS 6.3.svn (pat):~ > g.remove vect=lst_20050101_avg
reclassed
GRASS 6.3.svn (pat):~ > g.list rast | grep lst_20050101_avg
lst_20030114_avg lst_20050101_avg
lst_20030115_avg lst_20050101_avg_lstmodel
GRASS 6.3.svn (pat):~ > g.list vect | grep lst_
lst_20050101_avg lst_200501_avg_filt
GRASS 6.3.svn (pat):~ > r.info lst_20050101_avg | grep generated
| generated by r.series
GRASS 6.3.svn (pat):~ > g.gisenv
GISDBASE=/home/neteler/grassdata
LOCATION_NAME=pat
MAPSET=modisLSTzanzara
DEBUG=0
GRASS_GUI=text
MONITOR=x0
The problem seems to be in source:grass/trunk/general/manage/cmd/remove.c
(line 83) where it should not enter. Fix appreciated..
Ticket URL: <http://trac.osgeo.org/grass/ticket/54>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Keywords: |
reclassed
reclassed
LOCATION_NAME=pat
DEBUG=0
GRASS_GUI=text
MONITOR=x0
Can you test the attached patch?
(attachments)
g.remove-reclass.diff (4.39 KB)
neteler
3
Glynn
the suggested patch works. Please submit...
thanks
On Wed, Feb 20, 2008 at 4:48 AM, Glynn Clements
> Keywords: |
> reclassed
> reclassed
> LOCATION_NAME=pat
> DEBUG=0
> GRASS_GUI=text
> MONITOR=x0
GDAL
4
Reporter: neteler | Owner: grass-dev@…
Component: Default | Version: unspecified
Keywords: g.remove | Platform: Unspecified
Cpu: Unspecified |
Changes (by hamish):
* keywords: => g.remove
* platform: => Unspecified
* cpu: => Unspecified
Ticket URL: <https://trac.osgeo.org/grass/ticket/54#comment:1>
GDAL
5
Cpu: Unspecified |
Comment(by neteler):
Glynn Clements to grass-dev, 2/20/08
Ticket URL: <http://trac.osgeo.org/grass/ticket/54#comment:2>
GDAL
6
Cpu: Unspecified |
I wonder if this patch is still relevant since a reclass map bug was fixed
in r45699.
Ticket URL: <http://trac.osgeo.org/grass/ticket/54#comment:3>
GDAL
7
Type: defect | Status: closed
Resolution: fixed | Keywords: g.remove
Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
No complaints without the patch, it seems that r45699 fixed it. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/54#comment:4>
