[GRASS-dev] [GRASS GIS] #55: NVIZ. Shrinking of the surface when the surface resolution is increased
Reporter: clerici | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.2.3
Keywords: |
When the resolution of the current surface is increased (both in Coarse
Style and in Fine representations), the dimension of the surface is
progressively reduced. [[BR]]
The shrinking can be better evaluated by superimposing a vector map, as in
the attacched examples.[[BR]]
Example 1. Fine resolution =5[[BR]]
Example 2. Fine resolution =10
Ticket URL: <http://trac.osgeo.org/grass/ticket/55&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Component: NVIZ | Version: 6.2.3
Resolution: | Keywords:
Changes (by neteler):
  * component: default => NVIZ
Ticket URL: <http://trac.osgeo.org/grass/ticket/55#comment:1&gt;
Reporter: clerici | Owner: grass-dev@…
Priority: major | Milestone: 6.4.1
Component: NVIZ | Version: 6.4.0 RCs
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
Changes (by marisn):
  * platform: => Unspecified
  * version: 6.2.3 => 6.4.0 RCs
  * cpu: => Unspecified
  * milestone: 6.4.0 => 6.4.1
Comment:
Doesn't seem to get fixed for 6.4.0.
Must be some interesting resampling code. When resolution gets decreased,
borders are "floating" around instead of decreasing steady.
Ticket URL: <https://trac.osgeo.org/grass/ticket/55#comment:2&gt;
