#565: r.colors: glibc double free or corruption with -ae
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.5.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords: r.colors
Platform: Linux | Cpu: x86-32
Changes (by hamish):
* summary: r.colors: glibc double free error with -ae => r.colors: glibc
Comment:
here we go, happened again..
GRASS65svn> r.colors map1 color=bcyr -ae
Reading raster map <map1@user7>...
100%
*** glibc detected *** double free or corruption (!prev): 0x09a3a4f8 ***
Aborted
G> r.univar -g map1
n=301941
null_cells=0
min=-23.8941449919674
max=1999.8932486971
range=2023.78739368907
mean=68.8068337965498
mean_of_abs=71.8955312273628
stddev=259.955255789945
G> r.info -t map1
datatype=DCELL
G> gdb `which r.colors`
(gdb) run gauss color=bcyr -ae
Starting program: [...]/dist.i686-pc-linux-gnu/bin/r.colors map1
color=bcyr -ae
100%
*** glibc detected *** double free or corruption (!prev): 0x08e40a18 ***
Program received signal SIGABRT, Aborted.
0xb7f18424 in __kernel_vsyscall ()
(gdb) bt
#0 0xb7ef0424 in __kernel_vsyscall ()
#1 0xb7d31811 in raise () from /lib/tls/i686/cmov/libc.so.6
#2 0xb7d32fb9 in abort () from /lib/tls/i686/cmov/libc.so.6
#3 0xb7d66dfa in __fsetlocking () from /lib/tls/i686/cmov/libc.so.6
#4 0xb7d6e68f in mallopt () from /lib/tls/i686/cmov/libc.so.6
#5 0xb7d6e732 in free () from /lib/tls/i686/cmov/libc.so.6
#6 0xb7ea2cd6 in G_free (buf=0x9b7ba18) at alloc.c:129
#7 0x0804b386 in get_fp_stats (name=0x9b72640 "map1", mapset=0x9b72030
"user7",
statf=0xbfd05f94, min=3.2146326349358647, max=7.601348984183665,
geometric=0,
geom_abs=1) at stats.c:136
#8 0x0804a655 in main (argc=Cannot access memory at address 0x13d8
) at main.c:385
(gdb) frame 7
"user7",
geometric=0,
136 G_free(dcell);
(gdb) list
131 }
132 }
133
134 G_percent(row, nrows, 2);
135 G_close_cell(fd);
136 G_free(dcell);
137 }
(gdb) bt full
No locals.
"user7",
geometric=0,
dcell = (DCELL *) 0x9b7ba18
row = 477
col = 633
nrows = 477
ncols = 633
fd = 7
) at main.c:385
fpstats = {geometric = 0, geom_abs = 1, flip = 0, count = 1000,
min = 3.2146326349358647, max = 7.601348984183665, stats = 0x9b7cdf0,
total = 301941}
overwrite = 1
interactive = 0
this map was created with:
#spearfish
g.region n=4928010 s=4913700 w=590010 e=609000 res=30
#rows=477 cols=633 (odd number so there is a center cell)
#latest version from grass-addons svn
r.surf.volcano -g -r map2 peak=2000 crater=120
but that uses r.surf.gauss which changes each time you run it. The same
r.colors command runs to 100% with no problem with the exact same call to
r.surf.volcano.
r.mapcalc found no values exactly matching 0.00000 in the map.
It consistently breaks with this map, I can .tgz it if needed.
Here's the valgrind output:
G> CMD="r.colors map1 color=bcyr -ae"
G> valgrind -v --tool=memcheck --leak-check=yes $CMD
==7130== Memcheck, a memory error detector.
==7130== Copyright (C) 2002-2006, and GNU GPL'd, by Julian Seward et al.
==7130== Using LibVEX rev 1658, a library for dynamic binary translation.
==7130== Copyright (C) 2004-2006, and GNU GPL'd, by OpenWorks LLP.
==7130== Using valgrind-3.2.1-Debian, a dynamic binary instrumentation
framework.
==7130== Copyright (C) 2000-2006, and GNU GPL'd, by Julian Seward et al.
==7130==
--7130-- Command line
--7130-- r.colors
--7130-- map1
--7130-- color=bcyr
--7130-- -ae
--7130-- Startup, with flags:
--7130-- -v
--7130-- --tool=memcheck
--7130-- --leak-check=yes
--7130-- Contents of /proc/version:
--7130-- Linux version 2.6.26-bpo.1-686 (Debian 2.6.26-13~bpo40+1)
(nobse@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian
4.1.1-21)) #1 SMP Mon Jan 12 20:06:26 UTC 2009
--7130-- Arch and hwcaps: X86, x86-sse1-sse2
--7130-- Valgrind library directory: /usr/lib/valgrind
--7130-- Reading syms from /lib/ld-2.3.6.so (0x4000000)
--7130-- Reading debug info from /lib/ld-2.3.6.so...
--7130-- ... CRC mismatch (computed A2342EFB wanted 8FC9FDDB)
--7130-- object doesn't have a symbol table
--7130-- Reading syms from /usr/local/src/grass/svn/grass65/dist.i686-pc-
linux-gnu/bin/r.colors (0x8048000)
--7130-- Reading syms from /usr/lib/valgrind/x86-linux/memcheck
(0x38000000)
--7130-- object doesn't have a dynamic symbol table
--7130-- Reading suppressions file: /usr/lib/valgrind/default.supp
--7130-- Reading syms from /usr/lib/valgrind/x86-linux/vgpreload_core.so
(0x4019000)
linux/vgpreload_memcheck.so (0x401B000)
linux-gnu/lib/libgrass_gis.6.5.svn.so (0x4021000)
linux-gnu/lib/libgrass_datetime.6.5.svn.so (0x407A000)
--7130-- Reading syms from /usr/lib/libz.so.1.2.3 (0x409C000)
--7130-- Reading syms from /lib/tls/i686/cmov/libm-2.3.6.so (0x40B0000)
--7130-- Reading debug info from /lib/tls/i686/cmov/libm-2.3.6.so...
--7130-- ... CRC mismatch (computed 70BA299D wanted 3AF3BB73)
--7130-- Reading syms from /lib/tls/i686/cmov/libc-2.3.6.so (0x40D5000)
--7130-- Reading debug info from /lib/tls/i686/cmov/libc-2.3.6.so...
--7130-- ... CRC mismatch (computed B308380A wanted ED81AE67)
--7130-- Reading syms from /lib/tls/i686/cmov/libdl-2.3.6.so (0x4206000)
--7130-- Reading debug info from /lib/tls/i686/cmov/libdl-2.3.6.so...
--7130-- ... CRC mismatch (computed DE27AFD0 wanted AA9202FA)
--7130-- REDIR: 0x41407F0 (rindex) redirected to 0x401DF30 (rindex)
--7130-- REDIR: 0x413C970 (malloc) redirected to 0x401D306 (malloc)
--7130-- REDIR: 0x413FF30 (strcpy) redirected to 0x401E970 (strcpy)
--7130-- REDIR: 0x413A6B0 (free) redirected to 0x401CF20 (free)
--7130-- REDIR: 0x413FEC0 (strcmp) redirected to 0x401E2D0 (strcmp)
--7130-- REDIR: 0x4140430 (strlen) redirected to 0x401E200 (strlen)
--7130-- REDIR: 0x4140640 (strncmp) redirected to 0x401E260 (strncmp)
--7130-- REDIR: 0x413CD90 (realloc) redirected to 0x401D3B5 (realloc)
--7130-- REDIR: 0x4141610 (memmove) redirected to 0x401E520 (memmove)
--7130-- REDIR: 0x4141B20 (memcpy) redirected to 0x401EBE0 (memcpy)
--7130-- REDIR: 0x413C630 (calloc) redirected to 0x401C633 (calloc)
--7130-- REDIR: 0x413FD50 (index) redirected to 0x401E020 (index)
--7130-- REDIR: 0x413FBA0 (strcat) redirected to 0x401E5E0 (strcat)
--7130-- REDIR: 0x4141180 (memchr) redirected to 0x401E3F0 (memchr)
--7130-- REDIR: 0x41423C0 (rawmemchr) redirected to 0x401E5C0 (rawmemchr)
--7130-- REDIR: 0x4141680 (memset) redirected to 0x401E4F0 (memset)
==7130== Invalid read of size 4
==7130== at 0x804B320: get_fp_stats (stats.c:129)
==7130== by 0x804A654: main (main.c:385)
==7130== Address 0x4223EDC is 12 bytes before a block of size 4,000
alloc'd
==7130== at 0x401C6CA: calloc (vg_replace_malloc.c:279)
==7130== by 0x402EC00: G__calloc (alloc.c:74)
==7130== by 0x804B1B6: get_fp_stats (stats.c:101)
==7130==
==7130== Invalid write of size 4
==7130== at 0x804B325: get_fp_stats (stats.c:129)
alloc'd
72%
valgrind: m_mallocfree.c:194 (get_bszB_as_is): Assertion 'bszB_lo ==
bszB_hi' failed.
valgrind: Heap block lo/hi size mismatch: lo = 5120, hi = 5161.
Probably caused by overrunning/underrunning a heap block's bounds.
==7130== at 0x38016993: report_and_quit (m_libcassert.c:136)
==7130== by 0x38016CBF: vgPlain_assert_fail (m_libcassert.c:200)
==7130== by 0x3802049E: vgPlain_arena_free (m_mallocfree.c:191)
==7130== by 0x38036001: vgPlain_cli_free (replacemalloc_core.c:108)
==7130== by 0x380019DB: die_and_free_mem (mc_malloc_wrappers.c:111)
==7130== by 0x38036782: do_client_request (scheduler.c:1158)
==7130== by 0x380380A0: vgPlain_scheduler (scheduler.c:869)
==7130== by 0x38057012: run_a_thread_NORETURN (syswrap-linux.c:87)
sched status:
running_tid=1
Thread 1: status = VgTs_Runnable
==7130== at 0x401CFA5: free (vg_replace_malloc.c:233)
==7130== by 0x402ECD5: G_free (alloc.c:129)
==7130== by 0x403F248: G_zlib_read (flate.c:190)
==7130== by 0x4043E3A: read_data_fp_compressed (get_row.c:115)
==7130== by 0x40442D0: read_data (get_row.c:238)
==7130== by 0x4044F40: get_map_row_nomask (get_row.c:616)
==7130== by 0x4045047: get_map_row_no_reclass (get_row.c:646)
==7130== by 0x4045140: get_map_row (get_row.c:678)
==7130== by 0x404538E: G_get_raster_row (get_row.c:898)
==7130== by 0x4045435: G_get_d_raster_row (get_row.c:968)
==7130== by 0x804B229: get_fp_stats (stats.c:109)
Note: see also the FAQ.txt in the source distribution.
It contains workarounds to several common problems.
If that doesn't help, please report this bug to: www.valgrind.org
In the bug report, send all the above text, the valgrind
version, and what Linux distro you are using. Thanks.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/565#comment:1>
