The main blocker for the Mac has been partly fixed in trunk: broken volume display. Now it displays most of the time and only crashes randomly instead all the time. If Markus Metz has backported this to 6.4.x, I’m happy to test and see if it works the same way there.
Michael
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 13, 2013, at 2:20 PM, <grass-dev-request@lists.osgeo.org>
wrote:
Subject: Re: [GRASS-dev] GRASS GIS 6.4.3RC2 released
Date: February 13, 2013 1:32:11 PM MST
To: Helmut Kudrnovsky <hellik@web.de>
Cc: <grass-dev@lists.osgeo.org>
2013/2/3 Martin Landa <landa.martin@gmail.com>:
since it’s more than a month ago now, what about another another RC or
release?
agreed. After RC3 should come ideally final release.
sorry for bringing this issue back. We have 2 RCs released, RC2 is
almost 2(!) month old. I don’t see any blocker in trac [1], even
nothing noted on the dev’s wiki [2]. Is there any blocker, if so
please collect them in trac or at least note them on trac page [2].
Currently I am afraid that we have no clear idea what is the status of
critical issues which have been reported within various mails in
various threads by various persons.
Martin
[1] http://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&group=type&order=priority&priority=blocker&priority=critical&milestone=6.4.3&milestone=6.4.2&milestone=6.4.1&milestone=6.4.0
[2] http://trac.osgeo.org/grass/wiki/Grass6Planning#GRASS6.4.3
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Thu, Feb 14, 2013 at 2:09 AM, Michael Barton <Michael.Barton@asu.edu> wrote:
all the time. If Markus Metz has backported this to 6.4.x, I'm happy to
I have disabled the gvl_align_data() function in 6.5. and 6.4, as
suggested by you. All it does is reallocating memory to the minimum
that is needed. Memory consumption might thus be a bit larger in GRASS
6 than in GRASS 7, but with regard to the ogsf lib it should work
nevertheless because gvl_align_data() does not touch the actual data.
Another possible source of bugs is the wxPython part of wxNVIZ because
it uses ctypes. Does it make sense to test the old Tcl/Tk nviz and see
if volume display works there?
Markus M
Michael
____________________
C. Michael Barton
since it's more than a month ago now, what about another another RC or
release?
almost 2(!) month old. I don't see any blocker in trac [1], even
nothing noted on the dev's wiki [2]. Is there any blocker, if so
Martin
[1]
On Thu, Feb 14, 2013 at 9:45 AM, Markus Metz
Another idea: you could use the current libs, but an older wxGUI and
see if it works there.
Markus M
Michael
C. Michael Barton
release?
Martin
[1]
yes, I should be able to run it with the old tcltk - that would be a good test,
Helena
Markus M
Michael
C. Michael Barton
release?
Martin
[1]
Actually, I already tested that a couple months back. The TclTk volume display works fine even when wxPython display does not.
Michael
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
On Feb 14, 2013, at 7:40 AM, Helena Mitasova <hmitaso@ncsu.edu>
Helena
Markus M
Michael
C. Michael Barton
release?
Martin
[1]
Custom Query – GRASS GIS
[2] Grass6Planning – GRASS GIS
Martin Landa <landa.martin gmail.com> * Studijní program Geodézie a kartografie – GeoWikiCZ
but does it work with the latest changes? That was my main concern, Helena
Michael
C. Michael Barton
USA
Helena
Markus M
Michael
C. Michael Barton
release?
Martin
[1]
grass-dev mailing list
Hmmm. I'll test and see. Hopefully tonight or tomorrow.
Michael
C. Michael Barton
USA
On Feb 14, 2013, at 9:05 AM, Helena Mitasova <hmitaso@ncsu.edu>
Michael
C. Michael Barton
USA
Helena
Markus M
Michael
C. Michael Barton
release?
Martin
[1]
grass-dev Info Page
Just tested GRASS 6.4 release branch.
Both TclTk and wxPython work the same. They display the volumes at some resolutions and crash at others.
Michael
C. Michael Barton
USA
Michael
C. Michael Barton
USA
Helena
Markus M
Michael
C. Michael Barton
release?
Martin
[1]
grass-dev Info Page
BTW, I put the just compiled version of 6.4 RB up on my web site.
Michael
C. Michael Barton
USA
Michael
C. Michael Barton
USA
Helena
Markus M
Michael
C. Michael Barton
release?
Martin
[1]
grass-dev Info Page
I noticed that students had hard time finding or defining the path to the file exported by v.out.ogr
(in our case it was a kml file) because there is no browse button - is there a reason for the missing
Browse for this command?
r.out.gdal has such button and it was suggested but Helmut some time ago:
http://lists.osgeo.org/pipermail/grass-user/2009-July/051356.html
Helena
OGR access to vector data requires a data source name (dsn) and a
layer name. The data source could be a PostGIS database in which case
a browse button does not make sense. In other cases, e.g. kml or
shapefiles, the dsn can be a directory or file name, or both. This is
too much flexibility for an automatically generated gui and the reason
for the new interfaces for r.in.gdal and v.in.ogr.
You can also set the current working directory in the GUI with
Settings->GRASS working environment->Change working directory. This
affects only the GUI, not the shell.
Markus M
Helena
this is actually what I was looking for, I could not find it in GRASS6.4.3 but I see that it is in GRASS7.
It could resolve several issues for Windows users.
thanks a lot, Helena
Markus M
Helena
