[GRASS-dev] [GRASS GIS] #613: clean_temp: not safe for concurrent use
  Reporter: hamish | Owner: grass-dev@…
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.6.0
Component: Startup | Version: 6.4.0 RCs
Resolution: fixed | Keywords: clean_temp init grass.py
       CPU: All | Platform: All
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"73342" 73342]:
#!CommitTicketReference repository="" revision="73342"
init: clean mapset only after locking it (fixes #613, see #1286)
Only after we set the user-requested mapset as current (GISRC) and lock
it,
we can do the startup cleaning using clean_temp (to clean after previous
sessions
if needed).
The cleaning was in place at least since r11260 but it got moved to a
wrong place some
time after that but before r37863.
Ticket URL: <https://trac.osgeo.org/grass/ticket/613#comment:5&gt;
