#626: layers re-renamed after change properties (wxpython)
Reporter: cnielsen | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
In wxpython if you rename a layer (not with g.rename but with right-
click->rename) and then you change the properties, after closing
properties the name returns to the actual filename (eg.
archsites@PERMANENT).
