#652: GIS Manager map properties (wxpython)
Reporter: dvictori | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: GIS Manager | Platform: Unspecified
Cpu: All |
I have 2 maps on the GIS Manager, a raster and a vector, and the
raster is selected. If I try to change the vector properties, like
line color, by clicking in the edit preferences button of the vector
map (small button to the right of the map name), the d.rast dialog
opens (since the raster is selected) and not the d.vect dialog I
expected. In order to change the line color of the vector I first have
to select the vector map and then click on the preferences button.
Shouldn't just clicking on the button, regardless if the map is
selected or not, bring the correct preferences dialog?
I'm using Grass 6.4RC5 from les-ejk ubuntu repository
