#681: wxpython gui-module 'g.remove' remembers all files after deleting
Reporter: marmai | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: g.remove file list | Platform: Unspecified
Cpu: Unspecified |
I wanted to delete a couple of vector maps with the g.remove GUI module
(wxpython GUI). Within the GUI window I selected some vector maps and
used the 'Run' button. Afterwards I wanted to remove some more maps
(without closing the window of the g.remove module!). Then there are the
maps I already deleted still in the list of the maps to remove (this leads
to a couple of error messages when clicking the 'Run' button). If
I click in the 'list of the maps to remove' and delete them (by using
the 'del' key) then as soon as you select another map via the drop down
list
they will again be back in the list of the maps to be removed.
By closing the g.remove module GUI and opening it again everything works
as expected.
I am using GRASS 6.4.0RC4 on OpenSuse10.3.
Ticket URL: <http://trac.osgeo.org/grass/ticket/681>
