[GRASS-dev] [GRASS GIS] #688: wxgui - georectify: after finishing editing a point, next point should be activated
activated
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: wxgui georectify | Platform: Unspecified
      Cpu: Unspecified |
In the wxgui georectifier, I think it would be more intuitive to by
default jump to the next point in the list after having finished editing
the previous one. Currently, you create a point, edit the projected values
and then if you go on to put a second point, its coordinates replace those
of the first, unless you remember to click on the next line in the list of
points.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/688&gt;
activated
Reporter: mlennert | Owner: grass-dev@…
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [ticket:688 mlennert]:
points.
Jumping to the next point in the list would be possible, but when are you
finished editing the current point? For some points I spend some time
adjusting them until RMS error is ok, in this case I would not want
automatic jump to the next point. In the new Ground Control Point Manager,
there is a confirmation dialog to prevent accidental modification.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/688#comment:1&gt;
activated
      Type: enhancement | Status: closed
Resolution: wontfix | Keywords: wxgui georectify
  Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
  * status: new => closed
  * resolution: => wontfix
Comment:
Replying to [comment:1 mmetz]:
points.
you finished editing the current point? For some points I spend some time
I see your point. Have no idea how to solve this completely, but probably
your confirmation dialog is the best possible way.
Thanks !
Closing this wish.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/688#comment:2&gt;
