[GRASS-dev] [GRASS GIS] #748: Inconsistency (?) in GUI v.db.connect
Reporter: pvanbosgeo | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
For an existing vector layer I want to change the table linked to it.
Opening v.db.connect GUI, under the optional tab, after selecting table
name: the drop down list under 'Key column name' still shows the columns
of the current table connected, not the table selected in the drop down
list under 'Table name'
Ticket URL: <http://trac.osgeo.org/grass/ticket/748&gt;
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: v.db.connect
  Platform: Linux | Cpu: x86-64
Changes (by martinl):
  * keywords: => v.db.connect
  * component: default => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/748#comment:1&gt;
  Reporter: pvanbosgeo | Owner: martinl
      Type: defect | Status: assigned
* cc: grass-dev@lists.osgeo.org (added)
  * owner: grass-dev@lists.osgeo.org => martinl
  * status: new => assigned
Ticket URL: <http://trac.osgeo.org/grass/ticket/748#comment:2&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: v.db.connect
  * status: assigned => closed
  * resolution: => wontfix
Comment:
This bug will be hardly fixed in 6.x (already fixed in 7.x). Only one way
is to enter the column name manually.
Ticket URL: <http://trac.osgeo.org/grass/ticket/748#comment:3&gt;
