#842: wx location wizard: spincontrol busted for UTM zone
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: location wizard, utm | Platform: Linux
Cpu: x86-64 |
the spin control for selecting the UTM zone in the new wx Location
creation wizard is busted on multiple Debian/Lennies for me but works on
Michael's Mac.
For me it locks on zone "1" as soon as you try and change it.
The only way we've found to unstick it is to comment out the first place
the default value of 30 is set on line 710 ({{{ self.pval[num] = '30'
}}}), but then I get errors in the terminal because it is uninitialized
and if I continue past the resulting PROJ_INFO +lon_0 comes in at -183
degrees regardless of zone.
we tried changing the following with no luck:
- self.pval[num] = '30'
+ self.pval[num] = 30
* remove value=
* remove initial=
* remove style=
spin controls work ok for me in module dialogs, such as r.composite.
any ideas? anyone else see this?
also the wizard does not create UTM zones as GRASS's type PROJECTION_UTM
(1) but rather as expanded +proj4 terms as PROJECTION_OTHER (99). Lat/lon
correctly sets itself as PROJECTION_LL (3).
in the g.proj C code I have followed it as far as lib/proj/
convert.c's GPJ_osr_to_grass(), which has some code to
specifically find the UTM zone from the +proj string, but then
it trails off a bit.
Here is where it decides to use GRASS's lat/lon mode instead of
go on using an "other" custom +proj string:
if (G_strcasecmp(pszToken, "proj") == 0) {
/* The ll projection is known as longlat in PROJ.4 */
if (G_strcasecmp(pszValue, "longlat") == 0)
pszValue = "ll";
pszProj = pszValue;
continue;
but there is no similar short-circuit for UTM zones or state
plane. see also the GPJ_osr_to_grass() function header comments
about return value.
State Plane (PROJECTION_SP: 2) is less of a priority for now as the wx
wizard end of that hasn't been written yet, but some basic placeholder
code could go in.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/842>
