#895: Error linking GeoTiff file with r.external
Reporter: huhabla | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: r.external | Platform: Linux
Cpu: x86-32 |
I receiving an error while trying to link a geotiff file with r.external
into a spearfish60 location. The file was previously generated with
r.out.gdal.
The import of the same file with r.in.gdal works without problems.
The error message of r.external:
ERROR: Missing type: field in file
'/home/soeren/grassdata/spearfish60/user1/cell_misc/test/f_format'
Here the workflow:
GRASS 7.0.svn (spearfish60):~ > g.region rast=elevation.dem@PERMANENT
GRASS 7.0.svn (spearfish60):~ > r.out.gdal input=elevation.dem@PERMANENT
format=GTiff type=Float64 output=elevation.30m.tiff -c
Exporting to GDAL data type: Float64
Checking GDAl data type and nodata value
100%
Input raster map contains cells with NULL-value (no-data). The value nan
will be used to represent no-data values in the input map. You can specify
a nodata value with the nodata option.
Exporting to GDAL raster
100%
r.out.gdal complete.
GRASS 7.0.svn (spearfish60):~ > r.external input=elevation.30m.tiff
output=test
Projection of input dataset and current location appear to match
Importing band 1 of 1...
Soeren
Ticket URL: <http://trac.osgeo.org/grass/ticket/895>
