[GRASS-dev] [GRASS GIS] #913: (windows) r.external does not work in both osgeo4w and standalone packages
Reporter: lutra | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Keywords: | Platform: MSWindows XP
      Cpu: x86-32 |
When using r.external under windows trough qgis, the module finishes
correctly, but then when adding the raster to canvas the program returns
the following warnings
Cannot draw raster
Cannot start module
command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.d.rast.exe
map=land@demo
window=-7.1176e+06,1.32961e+06,4.89704e+06,7.80968e+06,1184,639<br><br>
GRASS_INFO_ERROR(2864,1): Unable to locate symbol <GDALAllRegister>
GRASS_INFO_END(2864,1)
and
Cannot query raster
Cannot start module
command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.g.info.exe
info=query rast=land@demo coor=-3.89397e+06,5.61803e+06<br><br>
GRASS_INFO_ERROR(1596,1): Unable to locate symbol <GDALAllRegister>
GRASS_INFO_END(1596,1)
and the raster appears all gray.
The same kind of messages are returned if using osgeo4w GRASS (not trough
QGIS) or the standalone installer
Under linux it seems to work all fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/913&gt;
Resolution: | Keywords: r.external, WinGrass, osgeo4w
  Platform: MSWindows XP | Cpu: x86-32
Changes (by neteler):
  * keywords: => r.external, WinGrass, osgeo4w
Comment:
To my knowledge the OSGeo4W-GRASS 6.4 binary is pretty old, there have
been fixes in r40741 (see also
https://trac.osgeo.org/grass/log/grass/branches/releasebranch_6_4/lib/gis/gdal.c).
See also #885
Ticket URL: <https://trac.osgeo.org/grass/ticket/913#comment:1&gt;
Comment (by lutra):
Thanks. So what is the next step, suggest the osgeo4w packager to update
GRASS?
Ticket URL: <https://trac.osgeo.org/grass/ticket/913#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.external, WinGrass, osgeo4w
Changes (by lutra):
  * status: new => closed
  * resolution: => fixed
Comment:
Ok, I noticed that today GRASS was updated in the osgeo4w installer. I
then tested r.external and all seems to works fine now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/913#comment:3&gt;
