[GRASS-dev] [GRASS GIS] #971: d.what.vect: doesn't query longitude=180-360
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Keywords: d.what.vect, LL | Platform: Linux
      Cpu: x86-32 |
If I set the region of a world map to center on Australia, d.what.vect
only gives query results for longitude<180.
it should automatically convert coords with 180-360 &/or -180-0 to match
the same standard as the read-map data uses.
(I expect this goes rather deeper than d.what.vect, and so has a higher
payoff for fixing..)
g.region w=25W e=25W res=0:30 -p
d.rast etopo2
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/971&gt;
