[GRASS-dev] [GRASS GIS] #980: WinGRASS shouldn't use Internet Explorer as a default browser
Reporter: marisn | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-releasebranch64
Keywords: | Platform: MSWindows Vista
      Cpu: x86-32 |
Current WinGRASS launcher sets GRASS_HTML_BROWSER to Internet Explorer and
thus doesn't respect users preferences. When it gets changed to explorer,
g.manual (and thus gis.m and wxgui) open manuals in users preferred
browser (i.e. new tab in Firefox) and user doesn't have to hack around
with env settings.
GRASS_HTML_BROWSER=explorer
Note missing quotes or path, as explorer.exe normally resides in PATH
(C:\windows) and gets called from shell script g.manual.
Tested on WinGRASS-6.4.SVN-r41233-1 running on Windows Vista.
Ticket URL: <http://trac.osgeo.org/grass/ticket/980&gt;
Resolution: | Keywords: wingrass
  Platform: MSWindows Vista | Cpu: x86-32
Changes (by hamish):
  * keywords: => wingrass
Comment:
see previous attempts in
  http://trac.osgeo.org/osgeo4w/ticket/86
and
  source:grass/trunk/mswindows/GRASS-Installer.nsi@41256#L535
help required to fix the FIXME.
Hamish
ps- please tag all WinGrass bugs with the "wingrass" keyword so they show
up on the errata page.
Ticket URL: <https://trac.osgeo.org/grass/ticket/980#comment:1&gt;
Comment (by hellik):
Replying to [comment:1 hamish]:
> and
ReadRegStr $R0 HKCR "http\shell\open\command" (in the NSIS-script) should
give the path to default browser (ie, firefox, opera or whatever).
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/980#comment:2&gt;
Comment (by marisn):
Replying to [comment:2 hellik]:
should give the path to default browser (ie, firefox, opera or whatever).
> Helmut
Your' doing it wrong. GRASS should not hardcode or try to guess current
default browser. Let Windows handle it. If user changes default Windows
browser, GRASS will use new one instead of old one.
There's an issue with current approach - when user opens GRASS help in
current WinGRASS within Internet Explorer, it's blocking wxgui command
output till IE window gets closed. If GRASS_HTML_BROWSER is set to
"explorer", then command output is not blocked.
Ticket URL: <http://trac.osgeo.org/grass/ticket/980#comment:3&gt;
Replying to [comment:3 marisn]:
> > Helmut
done in r41428, r41429, r41430.
tested a little bit with self compiled grass64, grass65, grass7. please
test the nightly builds.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/980#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass
Changes (by marisn):
  * status: new => closed
  * resolution: => fixed
Comment:
Works just fine - GRASS documentation for me opens in new Firefox tab :slight_smile:
Changing default Windows web browser immediately affects also GRASS (as it
should be). As a reporter I take my freedom to close this bug. If anybody
notices something bad - feel free to reopen it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/980#comment:5&gt;
