[GRASS-dev] [GRASS GIS] #998: v.colors color column selection bug - default GRASSRGB not show in dialog
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
When using v.colors via wxGUI, the default GRASSRGB is not show in the
dialog
but instead all existing table columns (see screenshot).
v.colors
#%Option
#% key: rgb_column
#% type: string
#% required: no
#% description: Name of color column to populate
#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
#% answer: GRASSRGB
#% guisection: Colors
#%End
In d.vect, the column selector in the "Colors" tab is deactivated (also
confusing).
For all such color column selectors, the "GRASSRGB" should be predefined
and be the first choice in the color column selector.
Ticket URL: <http://trac.osgeo.org/grass/ticket/998&gt;
Resolution: | Keywords: v.colors, columns
  Platform: Unspecified | Cpu: Unspecified
Changes (by hamish):
  * keywords: => v.colors, columns
Ticket URL: <https://trac.osgeo.org/grass/ticket/998#comment:1&gt;
  Reporter: neteler | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
* cc: grass-dev@lists.osgeo.org (added)
  * owner: grass-dev@lists.osgeo.org => martinl
  * status: new => assigned
Comment:
Replying to [ticket:998 neteler]:
dialog
> confusing).
Please try r41425. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/998#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.colors, columns
Changes (by neteler):
  * status: assigned => closed
  * resolution: => fixed
Comment:
Thanks for the fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/998#comment:3&gt;
