Thank you very much Anna!
I finally managed to compile the snapshot version you posted.
While compiling, I had this error
Errors in:
/home/Downloads/grass-6.4_2017/gui/wxpython
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Sep 4 16:52:36 PDT 2017
make: *** [default] Error 1
LinuxMint17 ~/Downloads/grass-6.4_2017 $ cd ./gui/wxpython/
LinuxMint17 ~/Downloads/grass-6.4_2017/gui/wxpython $ make
After running make in gui/wxpython. The GRASS was successfully compiled.
However the error still remained.
GRASS 6.4.6svn (default):~/Downloads/grass-6.4_2017 > Traceback (most recent
call last):
File "/usr/local/grass-6.4.6svn/etc/wxpython/wxgui.py", line 34, in
<module>
from lmgr.frame import GMFrame
File "/usr/local/grass-6.4.6svn/etc/wxpython/lmgr/frame.py", line 46, in
<module>
from lmgr.layertree import LayerTree, LMIcons
File "/usr/local/grass-6.4.6svn/etc/wxpython/lmgr/layertree.py", line 37,
in <module>
from mapdisp.frame import MapFrame
File "/usr/local/grass-6.4.6svn/etc/wxpython/mapdisp/frame.py", line 52,
in <module>
from wxplot.profile import ProfileFrame
File "/usr/local/grass-6.4.6svn/etc/wxpython/wxplot/profile.py", line 28,
in <module>
import wx.lib.plot as plot
File
"/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/plot.py", line
132, in <module>
raise ImportError, "Numeric,numarray or NumPy not found. \n" + msg
ImportError: Numeric,numarray or NumPy not found.
This module requires the Numeric/numarray or NumPy module,
which could not be imported. It probably is not installed
(it's not part of the standard Python distribution). See the
Numeric Python site (http://numpy.scipy.org) for information on
downloading source or binaries.
These are the configs that I used
CFLAGS="-g -Wall -O2" LDFLAGS="-s" ./configure \
--enable-64bit \
--with-libs=/usr/lib64 \
--with-cxx \
--with-freetype=yes \
--with-freetype-includes=/usr/include/freetype2 \
--with-postgres=no \
--with-sqlite=yes \
--enable-largefile=yes \
--with-tcltk-includes=/usr/include/tcl8.6 \
--with-opengl-libs=/usr/include/GL \
--with-readline \
--with-python=yes \
--with-wxwidgets \
--with-cairo \
GRASS is now configured for:
Source directory: /home/Downloads/grass-6.4_2017
Build directory: /home/Downloads/grass-6.4_2017
Installation directory: ${prefix}/grass-6.4.6svn
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -Wall -O2
C++ compiler: c++ -g -O2
Building shared libraries: yes
64bit support: yes
OpenGL platform: X11
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
Tcl/Tk NVIZ: yes
BLAS support: no
C++ support: yes
Cairo support: yes
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GEOS support: no
GLw support: no
LAPACK support: no
Large File support (LFS): yes
Motif support: no
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: no
Python support: yes
Readline support: yes
SQLite support: yes
Tcl/Tk support: yes
wxWidgets support: yes
TIFF support: yes
X11 support: yes
I attached the full log of the compilation in case you want to look further
into it
Best regards,
-- Tung
On Wed, Aug 30, 2017 at 12:14 PM, Anna Petrášová <kratochanna@gmail.com>
wrote:
Is this version from packages? There has been some fixes, so maybe if
you could download and compile the latest version:
https://grass.osgeo.org/grass64/source/snapshot/
On Wed, Aug 30, 2017 at 11:23 AM, Tung Nguyen <tungkttv@gmail.com> wrote:
> Hi Vero,
> Thanks for the suggestion! I'd love to however some of the tools we're
> using
> are only compatible with GRASS-GIS 6.4
> Best regards,
> -- Tung
> On Tue, Aug 29, 2017 at 10:55 PM, Veronica Andreo <veroandreo@gmail.com>
> wrote:
>> Hello Tung,
>> Have you considered moving to GRASS 7.2? The last update of GRASS 6.4
>> series (6.4.4) was released one year ago and won't receive further bug
>> fixing.
>> I would highly recommend to move to grass 7
>> Best,
>> Vero
>> El 30 ago. 2017 12:28 a.m., "Tung Nguyen" <tungkttv@gmail.com>
>> escribió:
>>> Hello GRASS dev,
>>> I'm using GRASS-GIS v6.4.3 on Linux Mint 17.3 Rosa but couldn't get
>>> the
>>> GUI to start. I have tried all solutions I could find to no avail.
>>> What I
>>> have tried so far:
>>> - Uninstall & reinstall numpy (numpy-1.13.1)
>>> - Uninstall (purge) and reinstall python-wxversion, python-wxgtk2.8
>>> then
>>> grass-core, grass-dev & grass-gui
>>> - Error message:
>>> Welcome to GRASS 6.4.3 (2013)
>>> GRASS homepage: http://grass.osgeo.org/
>>> This version running thru: Bash Shell (/bin/bash)
>>> Help is available with the command: g.manual -i
>>> See the licence terms with: g.version -c
>>> If required, restart the GUI with: g.gui wxpython
>>> When ready to quit enter: exit
>>> [Raster MASK present]
>>> GRASS 6.4.3 (default):~ > Traceback (most recent call last):
>>> File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 34, in <module>
>>> File "/usr/lib/grass64/etc/wxpython/lmgr/frame.py", line 46, in
>>> <module>
>>> File "/usr/lib/grass64/etc/wxpython/lmgr/layertree.py", line 37, in
>>> <module>
>>> File "/usr/lib/grass64/etc/wxpython/mapdisp/frame.py", line 52, in
>>> <module>
>>> File "/usr/lib/grass64/etc/wxpython/wxplot/profile.py", line 23, in
>>> <module>
>>> File
>>> line
>>> 132, in <module>
>>> the
>>> information
>>> on
>>> - Machine info:
>>> $ python --version
>>> Python 2.7.6
>>> $ inxi -Fxz
>>> System: Kernel: 4.4.0-28-generic x86_64 (64 bit gcc: 4.8.4)
>>> Desktop: Cinnamon 2.8.8 (Gtk 3.10.8) Distro: Linux Mint
>>> 17.3
>>> Rosa
>>> Graphics: Card: NVIDIA GM107GL [Quadro K620] bus-ID: 01:00.0
>>> Display Server: X.Org 1.17.1 driver: nvidia Resolution:
>>> 1920x1080@60.0hz, 1920x1080@60.0hz
>>> GLX Renderer: Quadro K620/PCIe/SSE2 GLX Version: 4.5.0
>>> NVIDIA
>>> 375.39 Direct Rendering: Yes
>>> Any suggestion would be appreciated. Thanks!
>>> -- Tung
>>> _______________________________________________
>>> grass-dev mailing list
>>> grass-dev@lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
> Thanks!
> -- Tung
