Hi All,
How to run grass module from C++ code.I am coding a small application using C++ I want to call grass commands from the application (g.gisenv)
this can be done in different ways
- python using gcmd.RunCommand(…)
- setup grass environment and execute from c++ code using system command system(“g.gisev”);
I dont want to call in these ways.
My requirement is different
I will link all grass libraries with my application.
init grass using g_gisinit(…)
specify a program {g.gisenv}
give the attributes required to the application
execute the function without spawning a new process [ I think its not possible
parse the result.
Display results to user
Any pointers will be much appreciated…
Regards
