could d.rast.leg somehow leverage below "library" code? At time it is
suboptimal in placing the legend next to a raster map while being
generally very handy for cmd line junkies...
thanks
On Wed, May 21, 2014 at 5:07 AM, <svn_grass@osgeo.org> wrote:
Author: annakrat
Date: 2014-05-20 20:07:17 -0700 (Tue, 20 May 2014)
New Revision: 60385
Modified:
grass/branches/releasebranch_7_0/gui/wxpython/mapwin/decorations.py
Log:
wxGUI/legend: change default legend position so that legend histogram is not cut off (merge from trunk, r60384)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapwin/decorations.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapwin/decorations.py 2014-05-21 03:06:27 UTC (rev 60384)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapwin/decorations.py 2014-05-21 03:07:17 UTC (rev 60385)
@@ -211,7 +211,7 @@
self._id = 0
self._name = 'legend'
# TODO: synchronize with d.legend?
- self._defaultAt = 'at=5,50,2,5'
+ self._defaultAt = 'at=5,50,7,10'
self._cmd = ['d.legend', self._defaultAt]
def GetPlacement(self, screensize):
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
Talking about wx monitors, d.rast.leg does not really place legend next to a raster map because GRASS_FRAME is not used at all. So it basically draws legend and then raster map over it, so you can just change the order and that should fix it but you will still have overlapping raster and legend.
Anna
On Wed, May 21, 2014 at 1:46 AM, Markus Neteler <neteler@osgeo.org> wrote:
could d.rast.leg somehow leverage below “library” code? At time it is
generally very handy for cmd line junkies…
thanks
Author: annakrat
New Revision: 60385
Modified:
Log:
— grass/branches/releasebranch_7_0/gui/wxpython/mapwin/decorations.py 2014-05-21 03:06:27 UTC (rev 60384)
@@ -211,7 +211,7 @@
self._id = 0
self._name = ‘legend’
- self._defaultAt = ‘at=5,50,2,5’
- self._defaultAt = ‘at=5,50,7,10’
self._cmd = [‘d.legend’, self._defaultAt]
grass-dev mailing list
grass-dev@lists.osgeo.org
