2014-06-04 19:17 GMT+02:00 <svn_grass@osgeo.org>:
1. Consolite option/flag mutually exslusive messages.
it would be nice to solve it in the parser level...
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
Martin
I was thinking about the same thing. Maybe add char *exclusive_group to Option and Flag and G_parser() takes care of exclusiveness?
On Wed, Jun 4, 2014 at 2:03 PM, Martin Landa <landa.martin@gmail.com> wrote:
- Consolite option/flag mutually exslusive messages.
it would be nice to solve it in the parser level…
Martin
grass-dev mailing list
grass-dev@lists.osgeo.org
There are two relatively straightforward cases for option
interdependencies:
1. At most one option from a set may be provided (mutual exclusivity).
2. At least one option from a set must be provided (more general form
of the ->required field).
Both of these requirements may apply, i.e. exactly one option from a
set must be provided.
But there may still be cases where that isn't sufficient, and you'd
need generalised boolean expressions. E.g. Where you need either A or
both of B and C. Or if you use A then B is required, otherwise it's
invalid.
It would be a fairly simple matter to add a function to evaluate a
boolean expression supplied by the module. But that wouldn't be much
help either to the GUI (which ideally would use the interdependency
information to e.g. grey out invalid options) or for generating error
messages (we want something more informative than "that combination of
options isn't valid").
So, in the first instance I'd suggest adding:
// at most one option from a set
void G_option_exclusive(const char *opt, ...);
// at least one option from a set
void G_option_required(const char *opt, ...);
// if the first option is present, at least one of the other
// options must also be present
void G_option_requires(const char *opt, ...);
All functions take a NULL-terminated list of option/flag names
(leading "-" indicates a flag).
The argument-checking code would be migrated to the new functions. Any
cases which still cannot be expressed would be reported to the list
for further consideration.
Once we've either covered all of the cases or concluding that any
remaining cases cannot reasonably be incorporated into any general
framework, we can work on exporting this information via
--interface-description etc.
My implementation of the “exclusive” member, which you reverted, can handle all these cases, I think. But since you reverted it, I think you didn’t agree with my interface or implementation?
IMO, passing option/flag names to G_option_required() has its own disadvantage because changing option/flag names takes more effort. If you have valid reasoning behind adding functions rather than adding a member, just like I did, I would prefer to pass *Option and *Flag pointers to those functions. But I guess it can be a little tricky to pass two different types of pointers.
On Jun 6, 2014 2:42 AM, “Glynn Clements” <glynn@gclements.plus.com> wrote:
Option and Flag and G_parser() takes care of exclusiveness?There are two relatively straightforward cases for option
interdependencies:
of the ->required field).Both of these requirements may apply, i.e. exactly one option from a
set must be provided.But there may still be cases where that isn’t sufficient, and you’d
both of B and C. Or if you use A then B is required, otherwise it’s
invalid.It would be a fairly simple matter to add a function to evaluate a
boolean expression supplied by the module. But that wouldn’t be much
messages (we want something more informative than “that combination of
options isn’t valid”).So, in the first instance I’d suggest adding:
void G_option_exclusive(const char *opt, …);// at least one option from a set
void G_option_required(const char *opt, …);// if the first option is present, at least one of the other
void G_option_requires(const char *opt, …);All functions take a NULL-terminated list of option/flag names
(leading “-” indicates a flag).The argument-checking code would be migrated to the new functions. Any
for further consideration.Once we’ve either covered all of the cases or concluding that any
–interface-description etc.–
Huidae Cho wrote:
My implementation of the "exclusive" member, which you reverted, can handle
all these cases, I think. But since you reverted it, I think you didn't
Not really.
[I also wanted to be able to discuss this starting from a blank slate,
without the temptation to take any specific approach as a "reference
point". But that alone wouldn't have been sufficient for reversion.]
Mostly, I find the interface to be cryptic. Information which should
(IMHO) be in one place is spread out across the individual options.
In order to understand the relationships, anyone reading the code
needs to examine all of the options, and collate them into groups
based upon matching group numbers. IOW, mentally replicate the
(non-trivial) algorithms which form the bulk of r60713. The fact that
this was deemed to require several examples (with comments) tends to
suggest that it isn't particularly intuitive.
Apart from that, declaring "rules" would make the transition more
straightforward, as it mirrors the structure of the existing code
(i.e. the "if (expression) error();" statements).
By itself, that wouldn't be sufficient reason to prefer a rule-based
approach if it is considered to be inferior on its own merits. But
given the extent of the changes, it might be enough to tip the balance
in the event that the choice between different approaches amounted to
a toss-up.
types of pointers.
Indeed. I originally considered passing the struct pointers before
realising that approach wouldn't allow both flags and options to be
used interchangeably. At least, not without changing the structures to
carry some kind of type signature, although that wouldn't be
particularly difficult, given that both structures have to be created
via the appropriate functions.
This issue can be mitigated somewhat by using opt->name in the call
rather than a string literal[1]. We'd still need to use a literal for
flags, though.
[1] If we do that, modules which use "opt1", "opt2", etc for the
variable names should be changed to use meaningful names. Actually,
that should be done regardless.
I somehow agree with you that my interface can be cryptic and requires some interpretation because information is spread out. I think we can define something like:
void G_option_exclusive(const char *name, …);
void G_option_required(const char *name, …);
void G_option_requires(const char *name, …);
Here, actually, name is not needed, but is there only for stdarg. And we use these functions:
G_option_exclusive(“format”, &opt1, &opt2, &flag1, NULL); // No opt1, opt2, and flag1 at all OR only one of them.
G_option_required(“required”, &opt1, &opt2, &flag1, NULL); // At least one of opt1, opt2, and flag1 must be given.
G_option_requires(“group1”, &opt1, &opt2, NULL); // opt1 and opt2 must be used together.
In each function, we can use the state variable in parser.c (st->first_option and st->first_flag) to find defined options and flags:
opt = &st->first_option;
while(opt){
struct Option *x;
va_start(ap, name);
while((x = va_arg(ap, struct Option *))){
if (x == opt) {
break;
va_end(ap);
opt = opt->next_opt;
flag = &st->first_flag;
while(flag){
similar code here…
On Mon, Jun 9, 2014 at 5:34 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
agree with my interface or implementation?Not really.
without the temptation to take any specific approach as a “reference
point”. But that alone wouldn’t have been sufficient for reversion.]Mostly, I find the interface to be cryptic. Information which should
(IMHO) be in one place is spread out across the individual options.In order to understand the relationships, anyone reading the code
suggest that it isn’t particularly intuitive.Apart from that, declaring “rules” would make the transition more
(i.e. the “if (expression) error();” statements).By itself, that wouldn’t be sufficient reason to prefer a rule-based
a toss-up.IMO, passing option/flag names to G_option_required() has its own
types of pointers.Indeed. I originally considered passing the struct pointers before
realising that approach wouldn’t allow both flags and options to be
carry some kind of type signature, although that wouldn’t be
via the appropriate functions.This issue can be mitigated somewhat by using opt->name in the call
rather than a string literal[1]. We’d still need to use a literal for
flags, though.[1] If we do that, modules which use “opt1”, “opt2”, etc for the
that should be done regardless.–
Maybe, we can use variadic macros in C99 to remove the first name argument.
#define G_option_exclusive(…) G__option_exclusive(NULL, VA_ARGS)
// options must also be presentvoid G_option_requires(const char *name, …);
G_option_requires(“group1”, &opt1, &opt2, NULL); // opt1 and opt2 must be used together.In each function, we can use the state variable in parser.c (st->first_option and st->first_flag) to find defined options and flags:
while(opt){
struct Option *x;
va_start(ap, name);
if (x == opt) {
break;
va_end(ap);
while(flag){
similar code here…
Interesting, actually this works better I think.
#define G_option_exclusive(…) G__option_exclusive(NULL, VA_ARGS, NULL)
G_option_exclusive(&opt1, &opt2, &flag1); // no need for the first name and last NULL arguments.
while(opt){
struct Option *x;
va_start(ap, name);
if (x == opt) {
break;
va_end(ap);
while(flag){
similar code here…
#define G_option_exclusive(...) G__option_exclusive(NULL, __VA_ARGS__,
NULL)G_option_exclusive(&opt1, &opt2, &flag1); // no need for the first name
and last NULL arguments.On Mon, Jun 9, 2014 at 11:13 AM, Huidae Cho <grass4u@gmail.com> wrote:
argument.#define G_option_exclusive(...) G__option_exclusive(NULL, __VA_ARGS__)
Note that C99 is not what GRASS currently requires. Details:
[GRASS-dev] C and C++ standards used by GRASS
http://lists.osgeo.org/pipermail/grass-dev/2014-March/068017.html
C code is supposed to conform to C89 and POSIX.
(C89 with POSIX extensions)
define something like:// at most one option from a set
void G_option_exclusive(const char *name, ...);// at least one option from a set
void G_option_required(const char *name, ...);// if the first option is present, at least one of the other
void G_option_requires(const char *name, ...);Here, actually, name is not needed, but is there only for stdarg. And we
use these functions:G_option_exclusive("format", &opt1, &opt2, &flag1, NULL); // No opt1,
G_option_required("required", &opt1, &opt2, &flag1, NULL); // At least
G_option_requires("group1", &opt1, &opt2, NULL); // opt1 and opt2 must
(st->first_option and st->first_flag) to find defined options and flags:opt = &st->first_option;
while(opt){
struct Option *x;
va_start(ap, name);
if (x == opt) {
break;
va_end(ap);
}flag = &st->first_flag;
while(flag){
similar code here...
}On Mon, Jun 9, 2014 at 5:34 AM, Glynn Clements <glynn@gclements.plus.com
handle
didn't
point". But that alone wouldn't have been sufficient for reversion.]Mostly, I find the interface to be cryptic. Information which should
suggest that it isn't particularly intuitive.Apart from that, declaring "rules" would make the transition more
(i.e. the "if (expression) error();" statements).By itself, that wouldn't be sufficient reason to prefer a rule-based
a toss-up.> IMO, passing option/flag names to G_option_required() has its own
you
member,
those
flags, though.[1] If we do that, modules which use "opt1", "opt2", etc for the
that should be done regardless.--
Glynn Clements <glynn@gclements.plus.com>_______________________________________________
GRASS doesn't require C99. In general, we try to keep the hard
dependencies to a bare minimium, particularly in core functionality
such as libgis.
In any case, the <stdarg.h> requirement for an explicit first argument
isn't a significant problem. The functions would never be called with
less than two arguments.
In the worst case, it complicates the implementation slightly, as we
can't simply iterate over all of the arguments using va_arg(), but
have to treat the explicit argument separately. That can be handled
like:
void G_option_exclusive(void *first, ...)
void *opt = first;
va_start(ap, first);
for (;
process(opt); // search for opt in options/flags
opt = va_arg(ap, void*);
if (!opt) // NULL terminator
break;
va_end(ap);
Right, G_option_exclusive(void *first, …) should work.
On Wed, Jun 11, 2014 at 6:43 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
GRASS doesn’t require C99. In general, we try to keep the hard
such as libgis.In any case, the <stdarg.h> requirement for an explicit first argument
isn’t a significant problem. The functions would never be called with
less than two arguments.In the worst case, it complicates the implementation slightly, as we
can’t simply iterate over all of the arguments using va_arg(), but
like:void G_option_exclusive(void *first, …)
void opt = first;
for (;{
opt = va_arg(ap, void);
break;
va_end(ap);
I think we need two more functions:
void G_option_exclusive(void *first, …);
void G_option_required(void *first, …);
void G_option_requires(void *first, …);
// if the first option is present, all the other options must also be present.
// same as multiple G_option_requires(first, opt)…
void G_option_requires_all(void *first, …);
// G_option_requires_all() doesn’t make the second/third… option require all the other options.
// if any option is present, all the other options must also be present.
// all or nothing from a set
void G_option_inclusive(void *first, …);
void opt = first;
for (;{
break;
va_end(ap);
// same as multiple G_option_requires(first, opt)...
void G_option_requires_all(void *first, ...);
As you note, this can be achieved with multiple G_option_requires()
calls.
void G_option_inclusive(void *first, ...);
This could be achieved with multiple G_option_requires_all() calls. Or
even multiple G_option_requires() calls, but the number of such calls
would grow quadratically.
Apart from minimising the number of calls, there's probably some value
in terms of "documentation" to having specific rules for these cases.
Ultimately, there's no limit to the number of functions which *might*
be required. We should aim to capture all of the common cases first,
then figure out how to deal with anything which remains.
I'll make a start on this.
A first draft of the code has been added in r60871. Not tested yet.
Looks good to me. I’ll try it with g.mlist/g.mremove later.
On Thu, Jun 19, 2014 at 10:58 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
I’ll make a start on this.
I assume G__check_option_rules() is supposed to be called by G_parser(). Then, instead of calling G_fatal_error, it should append errors to st->errors. If so… for g.mlist we can define two different versions of rules:
This version prints more correct errors because only present options/flags will be displayed in errors, but too much typing.
G_option_exclusive(flag.regex, flag.extended, NULL);
G_option_exclusive(flag.pretty, flag.full, NULL);
G_option_exclusive(flag.pretty, opt.output, NULL);
G_option_exclusive(flag.pretty, flag.mapset, NULL);
G_option_exclusive(flag.pretty, flag.type, NULL);
G_option_exclusive(flag.full, opt.output, NULL);
G_option_exclusive(flag.full, flag.mapset, NULL);
G_option_exclusive(flag.full, flag.type, NULL);
This version is shorter, but -p -f will print three errors including options/flags not present.
G_option_exclusive(flag.pretty, flag.full, opt.output, NULL);
G_option_exclusive(flag.pretty, flag.full, flag.mapset, NULL);
G_option_exclusive(flag.pretty, flag.full, flag.type, NULL);
Can we implement something like G_option_exclusive(pretty, full, G_option_or(output, mapset, type))?
pretty, full, and any of output, mapset, and type are mutually exclusive, but output, mapset, and type are not exclusive.
st->errors.
Okay; I presume that the intent is so that it will report all errors,
not just the first.
If so... for g.mlist we can define two different versions of
rules:This version prints more correct errors because only present options/flags
G_option_exclusive(flag.full, flag.type, NULL);This version is shorter, but -p -f will print three errors including
G_option_exclusive(flag.pretty, flag.full, flag.type, NULL);Can we implement something like
I'd rather stick to "flat" rules rather than heading in the direction
of generalised boolean expressions.
Not because it's hard to implement, but because it makes it harder to
utilise the information.
The next logical step is to include the rules in the
--interface-description output so that the GUI can convey the
relationships to the user. E.g. mutually-exclusive options might use
radio buttons, or greying-out excluded options. Options which are
required by another option could be marked as "required" when a value
is given for the first option. And so on.
Realistically, that requires that the rules belong to a finite set of
patterns.
How about another rule type:
G_option_excludes(flag.pretty, opt.output, flag.mapset, flag.type, NULL);
G_option_excludes(flag.full, opt.output, flag.mapset, flag.type, NULL);
where the first option excludes all remaining options.
This is essentially the negation of G_option_requires().
G_option_excludes() works for me.
On Fri, Jun 20, 2014 at 7:58 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
st->errors.Okay; I presume that the intent is so that it will report all errors,
not just the first.If so… for g.mlist we can define two different versions of
?I’d rather stick to “flat” rules rather than heading in the direction
of generalised boolean expressions.Not because it’s hard to implement, but because it makes it harder to
utilise the information.The next logical step is to include the rules in the
–interface-description output so that the GUI can convey the
required by another option could be marked as “required” when a value
is given for the first option. And so on.Realistically, that requires that the rules belong to a finite set of
patterns.pretty, full, and any of output, mapset, and type are mutually exclusive,
but output, mapset, and type are not exclusive.How about another rule type:
G_option_excludes(flag.full, opt.output, flag.mapset, flag.type, NULL);where the first option excludes all remaining options.
We also need to add option_rules or something to g.parser so that python scripts can have access to these functions. Something like:
#%option_rules
#% exclusive: -a, -b
#% requires_all: opt1, opt2, -a
#%end
scripts can have access to these functions. Something like:#%option_rules
G_parser().
not just the first.> If so... for g.mlist we can define two different versions of
> rules:
options/flags
> ?I'd rather stick to "flat" rules rather than heading in the direction
of generalised boolean expressions.Not because it's hard to implement, but because it makes it harder to
patterns.> pretty, full, and any of output, mapset, and type are mutually
exclusive,
NULL);
is this new API now stable enough to be actually used in C modules? Should
we start to replace the manual checks in modules with these functions? BTW,
documentation is still missing.
I attached a patch which should fix this ticket [1]: when user doesn't type
any command arguments and the module has no explicitly required options
(like g.region), it checks if there is any RULE_REQUIRED and if yes, it
opens GUI dialog.
Also I would consider a little bit better error message, the name of the
option is not very visible in the sentence. Perhaps using quotes or <>
around the option would help. Also, "Option myoption1 requires at least one
of myoption2" sounds weird, perhaps there should be special handling of
cases when there is just one option required. These are just details.
Anna
[1]http://trac.osgeo.org/grass/ticket/1778
parser.diff (1.27 KB)
