Ahoj,
po rychlem testu:
return receiver(*arguments, **named)
File "/opt/src/grass_trunk/dist.x86_64-pc-linux-
gnu/gui/wxpython/datacatalog/tree.py", line 363, in
OnRightClick
self._popupMenuLayer()
gnu/gui/wxpython/datacatalog/tree.py", line 725, in
_popupMenuLayer
self.selected_location.label == genv['LOCATION_NAME']:
UnboundLocalError
local variable 'genv' referenced before assignment
Ma
2016-04-13 5:20 GMT+02:00 <svn_grass@osgeo.org>:
Author: annakrat
Date: 2016-04-12 20:20:44 -0700 (Tue, 12 Apr 2016)
New Revision: 68256Added:
grass/trunk/gui/icons/grass/locked.png
grass/trunk/gui/icons/grass/unlocked.png
Modified:
grass/trunk/gui/wxpython/datacatalog/catalog.py
grass/trunk/gui/wxpython/datacatalog/frame.py
grass/trunk/gui/wxpython/datacatalog/toolbars.py
grass/trunk/gui/wxpython/datacatalog/tree.py
Log:
wxGUI: update data catalog - allow editing outside of current mapsetAdded: grass/trunk/gui/icons/grass/locked.png
(Binary files differ)
Property changes on: grass/trunk/gui/icons/grass/locked.png
___________________________________________________________________
Added: svn:mime-type
+ image/pngAdded: grass/trunk/gui/icons/grass/unlocked.png
Property changes on: grass/trunk/gui/icons/grass/unlocked.png
+ image/pngModified: grass/trunk/gui/wxpython/datacatalog/catalog.py
--- grass/trunk/gui/wxpython/datacatalog/catalog.py 2016-04-12 19:57:43 UTC (rev 68255)
+++ grass/trunk/gui/wxpython/datacatalog/catalog.py 2016-04-13 03:20:44 UTC (rev 68256)
@@ -84,3 +84,7 @@
def OnReloadCurrentMapset(self, event):
"""Reload current mapset tree only"""
self.tree.ReloadCurrentMapset()
+ def SetRestriction(self, restrict):
+ """Allow editing other mapsets or restrict editing to current mapset"""
+ self.tree.SetRestriction(restrict)Modified: grass/trunk/gui/wxpython/datacatalog/frame.py
--- grass/trunk/gui/wxpython/datacatalog/frame.py 2016-04-12 19:57:43 UTC (rev 68255)
+++ grass/trunk/gui/wxpython/datacatalog/frame.py 2016-04-13 03:20:44 UTC (rev 68256)
@@ -26,6 +26,7 @@
from datacatalog.tree import DataCatalogTree
from datacatalog.toolbars import DataCatalogToolbar+
class DataCatalogFrame(wx.Frame):
"""Frame for testing purposes only."""
def __init__(self, parent, giface=None):
@@ -37,7 +38,7 @@
self._giface = giface
self.panel = wx.Panel(self)- self.toolbar = DataCatalogToolbar(parent = self)
+ self.toolbar = DataCatalogToolbar(parent=self)
# workaround for http://trac.wxwidgets.org/ticket/13888
if sys.platform != 'darwin':
self.SetToolBar(self.toolbar)
@@ -46,7 +47,7 @@
self.tree = DataCatalogTree(parent=self.panel, giface=self._giface)
self.tree.InitTreeItems()
self.tree.ExpandCurrentMapset()
# buttons
self.btnClose = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
self.btnClose.SetToolTipString(_("Close GRASS GIS Data Catalog"))
@@ -90,3 +91,7 @@
+ self.tree.SetRestriction(restrict)Modified: grass/trunk/gui/wxpython/datacatalog/toolbars.py
--- grass/trunk/gui/wxpython/datacatalog/toolbars.py 2016-04-12 19:57:43 UTC (rev 68255)
+++ grass/trunk/gui/wxpython/datacatalog/toolbars.py 2016-04-13 03:20:44 UTC (rev 68256)
@@ -15,15 +15,18 @@
"""import wx
-from gui_core.toolbars import BaseToolbar, BaseIcons
+from gui_core.toolbars import BaseToolbar
from icons.icon import MetaIcon
from core.utils import _icons = {
'reloadTree': MetaIcon(img='redraw', label=_("Reload GRASS locations")),
- 'reloadMapset': MetaIcon(img='reload', label=_("Reload current GRASS mapset only"))
+ 'reloadMapset': MetaIcon(img='reload', label=_("Reload current GRASS mapset only")),
+ 'unlocked': MetaIcon(img='unlocked', label=_("Click to restrict editing to current mapset only")),
+ 'locked': MetaIcon(img='locked', label=_("Click to allow editing other mapsets")),
class DataCatalogToolbar(BaseToolbar):
"""Main data catalog toolbar
@@ -44,5 +47,17 @@
return self._getToolbarData((("reloadTree", icons["reloadTree"],
self.parent.OnReloadTree),
("reloadMapset", icons["reloadMapset"],
- self.parent.OnReloadCurrentMapset)
+ self.parent.OnReloadCurrentMapset),
+ ("lock", icons['locked'],
+ self.OnSetRestriction, wx.ITEM_CHECK)
+ def OnSetRestriction(self, event):
+ if self.GetToolState(self.lock):
+ self.SetToolNormalBitmap(self.lock, icons['unlocked'].GetBitmap())
+ self.SetToolShortHelp(self.lock, icons['unlocked'].GetLabel())
+ self.parent.SetRestriction(restrict=False)
+ else:
+ self.SetToolNormalBitmap(self.lock, icons['locked'].GetBitmap())
+ self.SetToolShortHelp(self.lock, icons['locked'].GetLabel())
+ self.parent.SetRestriction(restrict=True)Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2016-04-12 19:57:43 UTC (rev 68255)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2016-04-13 03:20:44 UTC (rev 68256)
@@ -32,6 +32,7 @@
from grass.pydispatch.signal import Signalimport grass.script as gscript
+from grass.script import gisenv
from grass.exceptions import CalledModuleError@@ -50,7 +51,7 @@
return tmp_gisrc_file, env-def getLocationTree(gisdbase, location, queue, mapsets=):
+def getLocationTree(gisdbase, location, queue, mapsets=None):
"""Creates dictionary with mapsets, elements, layers for given location.
Returns tuple with the dictionary and error (or None)"""
tmp_gisrc_file, env = getEnvironment(gisdbase, location, 'PERMANENT')
@@ -92,6 +93,64 @@
gscript.try_remove(tmp_gisrc_file)+def map_exists(name, element, env, mapset=None):
+ """Check is map is present in the mapset given in the environment
+ :param name: name of the map
+ :param element: data type ('raster', 'raster_3d', and 'vector')
+ :param env environment created by function getEnvironment
+ if not mapset:
+ mapset = gscript.run_command('g.mapset', flags='p', env=env).strip()
+ # change type to element used by find file
+ if element == 'raster':
+ element = 'cell'
+ elif element == 'raster_3d':
+ element = 'grid3'
+ # g.findfile returns non-zero when file was not found
+ # se we ignore return code and just focus on stdout
+ process = gscript.start_command('g.findfile', flags='n',
+ element=element, file=name, mapset=mapset,
+ stdout=gscript.PIPE, stderr=gscript.PIPE, env=env)
+ output, errors = process.communicate()
+ info = gscript.parse_key_val(output, sep='=')
+ # file is the key questioned in grass.script.core find_file()
+ # return code should be equivalent to checking the output
+ if info['file']:
+ return True
+ else:
+ return False
+class NameEntryDialog(TextEntryDialog):
+ def __init__(self, element, mapset, env, **kwargs):
+ TextEntryDialog.__init__(self, **kwargs)
+ self._element = element
+ self._mapset = mapset
+ self._env = env
+ id_OK = self.GetAffirmativeId()
+ self.Bind(wx.EVT_BUTTON, self.OnOK, self.FindWindowById(id_OK))
+ def OnOK(self, event):
+ new = self.GetValue()
+ if not new:
+ return
+ if map_exists(new, self._element, self._env, self._mapset):
+ dlg = wx.MessageDialog(self, message=_("Map of type {elem} <{name}> already exists in mapset <{mapset}>. "
+ "Do you want to overwrite it?").format(elem=self._element,
+ name=new, mapset=self._mapset),
+ caption=_("Overwrite?"), style=wx.YES_NO)
+ if dlg.ShowModal() == wx.ID_YES:
+ dlg.Destroy()
+ self._env['GRASS_OVERWRITE'] = '1'
+ self.EndModal(wx.ID_OK)
+ else:
+ dlg.Destroy()
+ return
+ else:
class DataCatalogNode(DictNode):
"""Node representing item in datacatalog."""
def __init__(self, label, data=None):
@@ -122,15 +181,16 @@
self.parent = parent
self.contextMenu.connect(self.OnRightClick)
self.itemActivated.connect(self.OnDoubleClick)
self._initVariables()def _initTreeItems(self, locations=None, mapsets=None):
"""Add locations, mapsets and layers to the tree.
Runs in multiple processes. Saves resulting data and error."""
# mapsets param currently unused
+ genv = gisenv()
if not locations:
- locations = GetListOfLocations(self.gisdbase)
+ locations = GetListOfLocations(genv['GISDBASE'])loc_count = proc_count = 0
queue_list =
@@ -141,13 +201,13 @@
nprocs = cpu_count()
except NotImplementedError:
nprocs = 4
results = dict()
errors =
location_nodes =
nlocations = len(locations)
grassdata_node = self._model.AppendNode(parent=self._model.root,
- label=_('GRASS locations ({})').format(self.gisdbase),
+ label=_('GRASS locations in {}').format(genv['GISDBASE']),
data=dict(type='grassdata'))
for location in locations:
results[location] = dict()
@@ -160,7 +220,7 @@q = Queue()
p = Process(target=getLocationTree,
- args=(self.gisdbase, location, q))
+ args=(genv['GISDBASE'], location, q))
p.start()queue_list.append(q)
@@ -212,6 +272,7 @@
child = None
return child+ genv = gisenv()
locationItem, mapsetItem = self.GetCurrentLocationMapsetNode()
if not locationItem or not mapsetItem:
return
@@ -224,11 +285,11 @@q = Queue()
- args=(self.gisdbase, locationItem.data['name'], q, mapsetItem.data['name']))
+ args=(genv['GISDBASE'], locationItem.data['name'], q, mapsetItem.data['name']))
p.start()
maps, error = q.get()
if error:
- raise CalledModuleError(e)
+ raise CalledModuleError(error)self._populateMapsetItem(mapsetItem, maps[mapsetItem.data['name']])
self.RefreshNode(mapsetItem)
@@ -251,6 +312,10 @@
"""Create popup menu for mapsets"""
raise NotImplementedError()+ def _popupMenuElement(self):
+ """Create popup menu for elements"""
+ raise NotImplementedError()
def _initVariables(self):
"""Init variables."""
self.selected_layer = None
@@ -258,11 +323,6 @@
self.selected_mapset = None
self.selected_location = None- gisenv = gscript.gisenv()
- self.gisdbase = gisenv['GISDBASE']
- self.glocation = gisenv['LOCATION_NAME']
- self.gmapset = gisenv['MAPSET']
def GetControl(self):
"""Returns control itself."""
return self
@@ -279,7 +339,7 @@
self.selected_layer = item
type = 'element'
item = item.parent
if type == 'element':
self.selected_type = item
type = 'mapset'
@@ -289,20 +349,22 @@
self.selected_mapset = item
type = 'location'
item = item.parent
if type == 'location':
self.selected_location = item
def OnSelChanged(self, event):
def OnRightClick(self, node):
"""Display popup menu."""
self.DefineItems(node)
if self.selected_layer:
- self._popupMenuLayer(self.selected_mapset.label == self.gmapset)
+ self._popupMenuLayer()
elif self.selected_mapset and not self.selected_type:
self._popupMenuMapset()
+ elif self.selected_type:
+ self._popupMenuElement()def OnDoubleClick(self, node):
"""Expand/Collapse node."""
@@ -310,7 +372,7 @@
self.CollapseNode(node, recursive=False)
else:
self.ExpandNode(node, recursive=False)
def ExpandCurrentLocation(self):
"""Expand current location"""
location = gscript.gisenv()['LOCATION_NAME']
@@ -323,9 +385,9 @@def GetCurrentLocationMapsetNode(self):
"""Get current mapset node"""
- location = gisenv['LOCATION_NAME']
- mapset = gisenv['MAPSET']
+ genv = gisenv()
+ location = genv['LOCATION_NAME']
+ mapset = genv['MAPSET']
locationItem = self._model.SearchNodes(name=location, type='location')
if not locationItem:
return None, None
@@ -335,7 +397,7 @@
return locationItem[0], Nonereturn locationItem[0], mapsetItem[0]
def ExpandCurrentMapset(self):
"""Expand current mapset"""
@@ -343,11 +405,13 @@
self.Select(mapsetItem, select=True)
self.ExpandNode(mapsetItem, recursive=True)+
class DataCatalogTree(LocationMapTree):
"""Data Catalog Tree constructor."""
super(DataCatalogTree, self).__init__(parent)
+ self._restricted = Trueself._initVariablesCatalog()
self.beginDrag = Signal('DataCatalogTree.beginDrag')
@@ -356,18 +420,18 @@
self.endEdit = Signal('DataCatalogTree.endEdit')self.Bind(wx.EVT_TREE_BEGIN_DRAG, lambda evt:
- self._emitSignal(evt.GetItem(), self.beginDrag, event=evt))
+ self._emitSignal(evt.GetItem(), self.beginDrag, event=evt))
self.Bind(wx.EVT_TREE_END_DRAG, lambda evt:
- self._emitSignal(evt.GetItem(), self.endDrag, event=evt))
+ self._emitSignal(evt.GetItem(), self.endDrag, event=evt))
self.beginDrag.connect(self.OnBeginDrag)
self.endDrag.connect(self.OnEndDrag)self.Bind(wx.EVT_TREE_BEGIN_LABEL_EDIT, lambda evt:
- self._emitSignal(evt.GetItem(), self.startEdit, event=evt))
+ self._emitSignal(evt.GetItem(), self.startEdit, event=evt))
self.Bind(wx.EVT_TREE_END_LABEL_EDIT, lambda evt:
- self._emitSignal(evt.GetItem(), self.endEdit, event=evt))
- ###self.startEdit.connect(self.OnStartEditLabel)
- ###self.endEdit.connect(self.OnEditLabel)
+ self._emitSignal(evt.GetItem(), self.endEdit, event=evt))
+ self.startEdit.connect(self.OnStartEditLabel)
+ self.endEdit.connect(self.OnEditLabel)def _initVariablesCatalog(self):
@@ -376,17 +440,20 @@
self.copy_mapset = None
self.copy_location = None+ def SetRestriction(self, restrict):
+ self._restricted = restrict
def _runCommand(self, prog, **kwargs):
cmdString = ' '.join(gscript.make_command(prog, **kwargs))
ret = RunCommand(prog, parent=self, **kwargs)return ret, cmdString
def InitTreeItems(self):
"""Add locations, mapsets and layers to the tree."""
self._initTreeItems()
- def OnCopy(self, event):
+ def OnCopyMap(self, event):
"""Copy layer or mapset (just save it temporarily, copying is done by paste)"""
self.copy_layer = self.selected_layer
self.copy_type = self.selected_type
@@ -394,15 +461,17 @@
self.copy_location = self.selected_location
label = _("Map <{layer}> marked for copying. "
"You can paste it to the current mapset "
- "<{mapset}>.".format(layer=self.copy_layer.label, mapset=self.gmapset))
+ "<{mapset}>.".format(layer=self.copy_layer.label, mapset=gisenv()['MAPSET']))
self.showNotification.emit(message=label)- def OnRename(self, event):
- """Rename levent with dialog"""
- if self.selected_layer:
- self.old_name = self.selected_layer.label
- self.new_name = self._getUserEntry(_('New name'), _('Rename map'), self.old_name)
- self.Rename()
+ def OnRenameMap(self, event):
+ """Rename layer with dialog"""
+ old_name = self.selected_layer.label
+ gisrc, env = getEnvironment(gisenv()['GISDBASE'], self.selected_location.label, mapset=self.selected_mapset.label)
+ new_name = self._getNewMapName(_('New name'), _('Rename map'),
+ old_name, env=env, mapset=self.selected_mapset.label, element=self.selected_type.label)
+ if new_name:
+ self.Rename(old_name, new_name)def OnStartEditLabel(self, node, event):
"""Start label editing"""
@@ -416,51 +485,44 @@
def OnEditLabel(self, node, event):
"""End label editing"""
if self.selected_layer and not event.IsEditCancelled():
- self.old_name = node.label
- Debug.msg(1, "End label edit {name}".format(name=self.old_name))
- self.new_name = event.GetLabel()
- self.Rename()
+ old_name = node.label
+ Debug.msg(1, "End label edit {name}".format(name=old_name))
+ new_name = event.GetLabel()
+ self.Rename(old_name, new_name)- def Rename(self):
+ def Rename(self, old, new):
"""Rename layer"""
- if self.selected_layer and self.new_name:
- string = self.old_name + ',' + self.new_name
- gisrc, env = getEnvironment(self.gisdbase, self.selected_location.label, self.selected_mapset.label)
- renamed = 0
- label = _("Renaming map <{name}>...").format(name=string)
- self.showNotification.emit(message=label)
- if self.selected_type.label == 'vector':
- renamed, cmd = self._runCommand('g.rename', vector=string, env=env)
- elif self.selected_type.label == 'raster':
- renamed, cmd = self._runCommand('g.rename', raster=string, env=env)
- else:
- renamed, cmd = self._runCommand('g.rename', raster3d=string, env=env)
- if renamed == 0:
- self.selected_layer.label = self.new_name
- self.selected_layer.data['name'] = self.new_name
- self.RefreshNode(self.selected_layer)
- self.showNotification.emit(message=_("{cmd} -- completed").format(cmd=cmd))
- Debug.msg(1, "LAYER RENAMED TO: " + self.new_name)
- gscript.try_remove(gisrc)
+ string = old + ',' + new
+ gisrc, env = getEnvironment(gisenv()['GISDBASE'], self.selected_location.label, self.selected_mapset.label)
+ label = _("Renaming map <{name}>...").format(name=string)
+ self.showNotification.emit(message=label)
+ if self.selected_type.label == 'vector':
+ renamed, cmd = self._runCommand('g.rename', vector=string, env=env)
+ elif self.selected_type.label == 'raster':
+ renamed, cmd = self._runCommand('g.rename', raster=string, env=env)
+ else:
+ renamed, cmd = self._runCommand('g.rename', raster3d=string, env=env)
+ if renamed == 0:
+ self.selected_layer.label = new
+ self.selected_layer.data['name'] = new
+ self.RefreshNode(self.selected_layer)
+ self.showNotification.emit(message=_("{cmd} -- completed").format(cmd=cmd))
+ Debug.msg(1, "LAYER RENAMED TO: " + new)
+ gscript.try_remove(gisrc)- def OnPaste(self, event):
- """Paste layer or mapset"""
+ def OnPasteMap(self, event):
+ """Paste layer"""
# copying between mapsets of one location
if not self.copy_layer:
GMessage(_("No map selected for copying."), parent=self)
return
- if self.selected_location == self.copy_location and \
- self.selected_mapset.data['name'] == gscript.gisenv()['MAPSET']:
- if self.selected_type:
- if self.copy_type.label != self.selected_type.label: # copy raster to vector or vice versa
- GError(_("Failed to copy map: invalid map type "
- "({} vs. {}).".format(self.copy_type.label, self.selected_type.label)), parent=self)
- return
- self.new_name = self._getUserEntry(_('New name'), _('Copy map'),
- self.copy_layer.label + '_copy')
- if not self.new_name:
+ if self.selected_location == self.copy_location:
+ new_name = self._getNewMapName(_('New name'), _('Copy map'),
+ self.copy_layer.label, env=env, mapset=self.selected_mapset.label, element=self.copy_type.label)
+ if not new_name:
return
- if self.copy_layer.label == self.new_name:
+ if map_exists(new_name, element=self.copy_type.label, env=env, mapset=self.selected_mapset.label):
GMessage(_("Failed to copy map: new map has the same name"), parent=self)
return@@ -470,21 +532,21 @@
overwrite = False
- found = self._model.SearchNodes(parent=self.selected_type, type=self.copy_type.label, name=self.new_name)
+ found = self._model.SearchNodes(parent=self.selected_type, type=self.copy_type.label, name=new_name)
if found and found[0]:
dlg = wx.MessageDialog(parent=self,
- message = _("Map <{map}> already exists "
- "in the current mapset. "
- "Do you want to overwrite it?").format(map=self.new_name),
- caption = _("Overwrite?"),
- style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ message=_("Map <{map}> already exists "
+ "in the current mapset. "
+ "Do you want to overwrite it?").format(map=new_name),
+ style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
ret = dlg.ShowModal()
dlg.Destroy()
if ret == wx.ID_YES:
overwrite = True- string = self.copy_layer.label + '@' + self.copy_mapset.label + ',' + self.new_name
+ string = self.copy_layer.label + '@' + self.copy_mapset.label + ',' + new_name
pasted = 0
label = _("Copying <{name}>...").format(name=string)
@@ -498,60 +560,63 @@
pasted, cmd = self._runCommand('g.copy', raster_3d=string, overwrite=overwrite, env=env)
node = 'raster_3d'
if pasted == 0:
- if not self.selected_type:
- # add type node if not exists
- self.selected_type = self._model.AppendNode(parent=self.selected_mapset, label=node,
- data=dict(type='element', name=node))
- if not overwrite:
- self._model.AppendNode(parent=self.selected_type, label=self.new_name,
- data=dict(type=node, name=self.new_name))
- self._model.SortChildren(self.selected_type)
- self.RefreshNode(self.selected_type, recursive=True)
- Debug.msg(1, "COPIED TO: " + self.new_name)
- self.showNotification.emit(message= _("{cmd} -- completed").format(cmd=cmd))
+ self.InsertLayer(name=new_name, mapset_node=self.selected_mapset, element_name=node)
+ Debug.msg(1, "COPIED TO: " + new_name)
+ self.showNotification.emit(message=_("g.copy completed").format(cmd=cmd))
else:
- if self.selected_location != self.copy_location:
- GError(_("Failed to copy map: action is allowed only within the same location."),
- parent=self)
- else:
- GError(_("Failed to copy map: action is allowed only within the current mapset."),
- parent=self)
+ GError(_("Failed to copy map: action is allowed only within the same location."),
+ parent=self)
# expand selected mapset
self.ExpandNode(self.selected_mapset, recursive=True)- def OnDelete(self, event):
+ def InsertLayer(self, name, mapset_node, element_name):
+ """Insert layer into model and refresh tree"""
+ found_element = self._model.SearchNodes(parent=mapset_node, type='element', name=element_name)
+ found_element = found_element[0] if found_element else None
+ if not found_element:
+ # add type node if not exists
+ found_element = self._model.AppendNode(parent=mapset_node, label=element_name,
+ data=dict(type='element', name=element_name))
+ found = self._model.SearchNodes(parent=found_element, name=name)
+ if len(found) == 0:
+ self._model.AppendNode(parent=found_element, label=name,
+ data=dict(type=element_name, name=name))
+ self._model.SortChildren(found_element)
+ self.RefreshNode(mapset_node, recursive=True)
+ def OnDeleteMap(self, event):
"""Delete layer or mapset"""
- string = self.selected_layer.label
- removed = 0
- # TODO: rewrite this that it will tell map type in the dialog
- if self._confirmDialog(question=_('Do you really want to delete map <{m}>?').format(m=string),
- title=_('Delete map')) == wx.ID_YES:
- label = _("Deleting {name}...").format(name=string)
- removed, cmd = self._runCommand('g.remove', flags='f', type='vector',
- name=string, env=env)
- removed, cmd = self._runCommand('g.remove', flags='f', type='raster',
- else:
- removed, cmd = self._runCommand('g.remove', flags='f', type='raster_3d',
- if removed == 0:
- self._model.RemoveNode(self.selected_layer)
- Debug.msg(1, "LAYER " + string + " DELETED")
+ name = self.selected_layer.label
+ if self._confirmDialog(question=_("Do you really want to delete map <{m}> of type <{etype}> from mapset "
+ "<{mapset}> in location <{loc}>?").format(m=name, mapset=self.selected_mapset.label,
+ etype=self.selected_type.label,
+ loc=self.selected_location.label),
+ title=_('Delete map')) == wx.ID_YES:
+ label = _("Deleting {name}...").format(name=name)
+ removed, cmd = self._runCommand('g.remove', flags='f', type='vector',
+ name=name, env=env)
+ removed, cmd = self._runCommand('g.remove', flags='f', type='raster',
+ else:
+ removed, cmd = self._runCommand('g.remove', flags='f', type='raster_3d',
+ if removed == 0:
+ self._model.RemoveNode(self.selected_layer)
+ self.RefreshNode(self.selected_type, recursive=True)
+ Debug.msg(1, "LAYER " + name + " DELETED")
+ self.showNotification.emit(message=_("g.remove completed").format(cmd=cmd))
+ gscript.try_remove(gisrc)def OnDisplayLayer(self, event):
"""Display layer in current graphics view"""
layerName =
- if self.selected_location.label == self.glocation and self.selected_mapset:
+ if self.selected_location.label == gisenv()['LOCATION_NAME'] and self.selected_mapset:
string = self.selected_layer.label + '@' + self.selected_mapset.label
layerName.append(string)
label = _("Displaying {name}...").format(name=string)
@@ -573,35 +638,39 @@def OnBeginDrag(self, node, event):
"""Just copy necessary data"""
- if wx.GetMouseState().ControlDown():
- #cursor = wx.StockCursor(wx.CURSOR_HAND)
- #self.SetCursor(cursor)
+ self.DefineItems(node)
+ if self.selected_layer and \
+ not (self._restricted and gisenv()['LOCATION_NAME'] != self.selected_location.label):
event.Allow()
- self.DefineItems(node)
- self.OnCopy(event)
+ self.OnCopyMap(event)
Debug.msg(1, "DRAG")
else:
event.Veto()
- Debug.msg(1, "DRAGGING without ctrl key does nothing")def OnEndDrag(self, node, event):
"""Copy layer into target"""
- #cursor = wx.StockCursor(wx.CURSOR_ARROW)
+ if not wx.GetMouseState().ControlDown():
+ GMessage(_("Moving maps not implemented"), parent=self)
+ event.Veto()
+ return
if node:
+ if self._restricted and gisenv()['MAPSET'] != self.selected_mapset.label:
+ GMessage(_("Maps can be copied only to current mapset"), parent=self)
+ event.Veto()
+ return
if self.selected_location == self.copy_location and self.selected_mapset:
event.Allow()
- self.OnPaste(event)
- #cursor = wx.StockCursor(wx.CURSOR_DEFAULT)
- #self.SetCursor(cursor) # TODO: change cursor while dragging and then back, this is not working
+ self.OnPasteMap(event)
Debug.msg(1, "DROP DONE")
else:
event.Veto()- def _getUserEntry(self, message, title, value):
+ def _getNewMapName(self, message, title, value, element, mapset, env):
"""Dialog for simple text entry"""
- dlg = TextEntryDialog(self, message, title)
+ dlg = NameEntryDialog(parent=self, message=message, caption=title,
+ element=element, env=env, mapset=mapset)
dlg.SetValue(value)
if dlg.ShowModal() == wx.ID_OK:
name = dlg.GetValue()
@@ -618,28 +687,43 @@
dlg.Destroy()
return res- def _popupMenuLayer(self, current_mapset):
+ def _popupMenuLayer(self):
"""Create popup menu for layers"""
menu = wx.Menu()
+ if self._restricted:
+ genv = gisenv()
+ currentMapset = currentLocation = False
+ if self.selected_location.label == genv['LOCATION_NAME']:
+ currentLocation = True
+ if self.selected_mapset.label == genv['MAPSET']:
+ currentMapset = True
+ else:
+ currentMapset = currentLocation = Trueitem = wx.MenuItem(menu, wx.NewId(), _("&Copy"))
menu.AppendItem(item)
- self.Bind(wx.EVT_MENU, self.OnCopy, item)
+ self.Bind(wx.EVT_MENU, self.OnCopyMap, item)
+ item.Enable(currentLocation)- item = wx.MenuItem(menu, wx.NewId(), _("&Delete"))
+ item = wx.MenuItem(menu, wx.NewId(), _("&Paste"))
- self.Bind(wx.EVT_MENU, self.OnDelete, item)
- if not current_mapset:
+ self.Bind(wx.EVT_MENU, self.OnPasteMap, item)
+ if not(currentLocation and self.copy_layer and self.selected_location == self.copy_location):
item.Enable(False)+ item = wx.MenuItem(menu, wx.NewId(), _("&Delete"))
+ menu.AppendItem(item)
+ self.Bind(wx.EVT_MENU, self.OnDeleteMap, item)
+ item.Enable(currentMapset)
item = wx.MenuItem(menu, wx.NewId(), _("&Rename"))
- self.Bind(wx.EVT_MENU, self.OnRename, item)
- item.Enable(False)
+ self.Bind(wx.EVT_MENU, self.OnRenameMap, item)
+ item.Enable(currentMapset)- if not isinstance(self._giface, StandaloneGrassInterface):
- item = wx.MenuItem(menu, wx.NewId(), _("&Display"))
+ if not isinstance(self._giface, StandaloneGrassInterface) and \
+ self.selected_location.label == genv['LOCATION_NAME']:
+ item = wx.MenuItem(menu, wx.NewId(), _("&Display layer"))
self.Bind(wx.EVT_MENU, self.OnDisplayLayer, item)@@ -652,7 +736,21 @@
- self.Bind(wx.EVT_MENU, self.OnPaste, item)
+ if not (self.copy_layer and self.selected_location == self.copy_location):
+ item.Enable(False)self.PopupMenu(menu)
menu.Destroy()
+ menu = wx.Menu()
+ self.PopupMenu(menu)
+ menu.Destroy()_______________________________________________
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
