[GRASS-dev] [GRASS-SVN] r73692 - grass/trunk/lib/init
st 21. 11. 2018 v 20:05 odesílatel <svn_grass@osgeo.org> napsal:
+ # clean the sqlite db
+ from grass.script import db as gdb
+ from grass.script import core as gcore
+ conn = gdb.db_connection()
+ if conn and conn['driver'] == 'sqlite':
+ # check if db exists
+ gisenv = gcore.gisenv()
+ database = conn['database']
+ database = database.replace('$GISDBASE', gisenv['GISDBASE'])
+ database = database.replace('$LOCATION_NAME', gisenv['LOCATION_NAME'])
+ database = database.replace('$MAPSET', gisenv['MAPSET'])
+ if os.path.exists(database):
+ message(_("Cleaning up sqlite database ..."))
+ gcore.start_command('db.execute', sql = 'VACUUM')
a small note, the added code could be probably moved to new a fn eg.
clean_db(), Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Wed, Nov 21, 2018 at 2:12 PM Martin Landa <landa.martin@gmail.com> wrote:
  • clean the sqlite db
  • from grass.script import db as gdb
  • from grass.script import core as gcore
  • conn = gdb.db_connection()
  • if conn and conn[‘driver’] == ‘sqlite’:
  • check if db exists
  • gisenv = gcore.gisenv()
  • database = conn[‘database’]
  • database = database.replace(‘$GISDBASE’, gisenv[‘GISDBASE’])
  • database = database.replace(‘$LOCATION_NAME’, gisenv[‘LOCATION_NAME’])
  • database = database.replace(‘$MAPSET’, gisenv[‘MAPSET’])
  • if os.path.exists(database):
  • message(_(“Cleaning up sqlite database …”))
  • gcore.start_command(‘db.execute’, sql = ‘VACUUM’)
clean_db(), Ma
Yes, ideally to grass.script.setup.
clean_db(), Ma
But this is only initializing a GRASS session, without any mechanism to terminate a session. Basic usage in the documentation:
… use GRASS modules here
remove the session’s gisrc file to end the session
os.remove(gisrc)
maybe a new fn to terminate a session is needed? This fn could clean temp files like clean_temp() in grass.py and also clean any default sqlite db when terminating the grass session.
Markus M
On Thu, Nov 22, 2018 at 10:57 AM Markus Metz <markus.metz.giswork@gmail.com> wrote:
clean_db(), Ma
os.remove(gisrc)
That’s all correct. There would have to be more to make it the same procedure as in grass.py, but eventually we need to do that.
What I meant to add it to grass.script.setup module where we should eventually put all the functions needed to setup a proper GRASS session (or in some other module, but setup seems to be something good enough for now and moving things around while keeping the API is easy in Python).
clean_db(), Ma
os.remove(gisrc)
ok, the db cleanup is now (r73704) a function in grass.script.setup
On Sat, Nov 24, 2018 at 5:54 AM Markus Metz <markus.metz.giswork@gmail.com> wrote:
Great! Thanks. I tried to clean grass.py as much as possible, so I hope it’s possible to make changes there.
Unfortunately, just running:
$ grass77 --tmp-location XY --exec g.region -p
Execution of <g.region -p> finished.
File “./bin.x86_64-pc-linux-gnu/grass77”, line 2260, in
main()
File “./bin.x86_64-pc-linux-gnu/grass77”, line 2208, in main
clean_all(params.tmp_location)
TypeError: clean_all() takes no arguments (1 given)
$ svnversion
73707M
main()
oops, fixed in r73708
Markus M
$ svnversion
73707M
