[GRASS-dev] [GRASS-SVN] r73769 - grass/trunk/locale/po
Hi Huidae,
On Wed, Dec 5, 2018 at 1:39 PM <svn_grass@osgeo.org> wrote:
Author: hcho
Date: 2018-12-05 04:39:10 -0800 (Wed, 05 Dec 2018)
New Revision: 73769
Modified:
   grass/trunk/locale/po/grasslibs_ko.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grasswxpy_ko.po
Log:
i18n: Update Korean POs
just a question: did you update this using the transifex_merge script?
Otherwise the work may get lost until we have "tx push" working.
Yes, I did use the transifex_merge script (changed -a to -l ko).
Huidae
Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
Open Source GIS Developer, GRASS GIS Development Team
Feel free to just update all language files at the same time :slight_smile:
Sure, no problem. It was just faster to do Korean only for testing.
Huidae
