[GRASS-dev] [GRASS-SVN] r74358 - grass/trunk/lib/python/temporal
it should really be >= 3 to avoid failing for future Python versions:
http://astrofrog.github.io/blog/2016/01/12/stop-writing-python-4-incompatible-code/
On Tue, Apr 9, 2019 at 5:07 AM <svn_grass@osgeo.org> wrote:
Author: sbl
Date: 2019-04-09 02:07:30 -0700 (Tue, 09 Apr 2019)
New Revision: 74358
Modified:
grass/trunk/lib/python/temporal/datetime_math.py
grass/trunk/lib/python/temporal/temporal_algebra.py
Log:
fix python version check
Modified: grass/trunk/lib/python/temporal/datetime_math.py
— grass/trunk/lib/python/temporal/datetime_math.py 2019-04-08 19:50:21 UTC (rev 74357)
+++ grass/trunk/lib/python/temporal/datetime_math.py 2019-04-09 09:07:30 UTC (rev 74358)
@@ -19,7 +19,7 @@
except:
has_dateutil = False
-if sys.version_info[0]:
+if sys.version_info[0] == 3:
unicode = str
DAY_IN_SECONDS = 86400
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
— grass/trunk/lib/python/temporal/temporal_algebra.py 2019-04-08 19:50:21 UTC (rev 74357)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2019-04-09 09:07:30 UTC (rev 74358)
@@ -470,7 +470,7 @@
from .datetime_math import create_time_suffix
from .datetime_math import create_numeric_suffix
unicode = str
grass-commit mailing list
grass-commit@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-commit
Documented here:
https://trac.osgeo.org/grass/wiki/Python3Support#HowtowritePython3compatiblecode
On Tue, Apr 9, 2019 at 10:34 PM Anna Petrášová <kratochanna@gmail.com> wrote:
Author: sbl
New Revision: 74358
Modified:
Log:
@@ -19,7 +19,7 @@
except:
unicode = str
@@ -470,7 +470,7 @@
unicode = str
Hi Anna and others,
Sorry for the mistake and thanks for the heads up! Good to see that experienced devs are on the watch!
Fixed in r74361
For the record, there is still:
lib/python/imaging/images2swf.py:87:PY3 = sys.version_info[0] == 3
which I did not touch.
Stefan
Documented here:
Author: sbl
New Revision: 74358
Modified:
Log:
@@ -19,7 +19,7 @@
except:
unicode = str
@@ -470,7 +470,7 @@
unicode = str
