---------- Forwarded message ----------
Date: Wed, 1 Sep 2010 07:39:26 +0200
Subject: Re: [GRASS-user] g.extension not working
To: Daniel Victoria <daniel.victoria@gmail.com>
Yes, that's the reason then (same here).
We need to add a condition to skip the install ste in this case.
On 9/1/10, Daniel Victoria <daniel.victoria@gmail.com> wrote:
I do have /usr/bin/install installed. I run Ubuntu and coreutils is
the latest version.One small quirk though. I compiled Grass 6.5svn running make but I did
not install it (make install). I'm running it straigh from the build
directory (start script at ./bin.i686-pc-linux-gnu and binaries at
./dist.i686-pc-linux-gnu). Could that be related?Thanks
DanielOn Tue, Aug 31, 2010 at 10:01 PM, Hamish <hamish_b@yahoo.com> wrote:
Daniel wrote:
Ok, g.extension works and downloads svn addons
great! thanks for the confirmation.
but r.stream.extract compilation fails.
Bellow is the r.stream.order compilation log error.
make[1]: Leaving directory
ok, so actually it built ok, but fails during installation:
Installing r.stream.order...
/usr/bin/install: cannot stat
aka the "install" program is not installed.
No idea what provides that on your linux distro, on Debian and Ubuntu
it comes in the "coreutils" package.Hamish
grass-user mailing list
grass-user@lists.osgeo.org
