[GRASS-dev] [GRASS-user] Geomorphons and extension manager
I’m having similar problems with the extension manage on the Mac currently and filed a bug report.
Michael
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Feb 26, 2013, at 10:40 AM, <grass-user-request@lists.osgeo.org>
wrote:
Subject: [GRASS-user] Geomorphons and extension manager
Date: February 26, 2013 10:20:42 AM MST
To: <grass-user@lists.osgeo.org>
Cc: Phillip Owens <prowens@purdue.edu>
To whom it may concern,
I am trying to use extension manager in grass to install geomrphons. However, I am having trouble with the extension manager(error below). I emailed the geomorphon developer Jarek Jasiewicz(See Below) and he suggest I contact the GRASS-Users forum.
Please advise,
-Robert Brown
Subject: Re: Geomorphons
Date: February 26, 2013 11:56:20 AM EST
To: brown782@purdue.edu
On 02/26/2013 05:21 PM, brown782@purdue.edu wrote:
Dear Sir,
I use grass on my Mac OS X 10.8.2. I have been trying to compile grass to install the add-on Geomorphons. However, it is overwhelming to compile grass from source code as I have very little experience compiling programs. When I saw that your Geomorphons algorithm was part of the grass 7.0 add-ons I was pleased and tried to use the extension manager to add it to my grass add-on repository, however, I get an several errors which I have posted below. Any Suggestions?
g.extension extension=r.geomorphon/ operation=add
Fetching <r.geomorphon/> from GRASS-Addons SVN (be patient)…
Compiling…
In file included from geom.c:1:
local_proto.h:1:20: error: stdlib.h: No such file or
directory
local_proto.h:2:20: error: string.h: No such file or
directory
local_proto.h:3:18: error: math.h: No such file or directory
local_proto.h:4:27: error: grass/glocale.h: No such file or
directory
local_proto.h:5:23: error: grass/gis.h: No such file or
directory
local_proto.h:6:26: error: grass/raster.h: No such file or
directory
local_proto.h:56: error: expected specifier-qualifier-list
before ‘RASTER_MAP_TYPE’
local_proto.h:66: error: expected specifier-qualifier-list
local_proto.h:74: error: expected specifier-qualifier-list
before ‘CELL’
local_proto.h:139: error: expected declaration specifiers or
‘…’ before ‘RASTER_MAP_TYPE’
local_proto.h:140: error: expected ‘)’ before ‘’ token
geom.c: In function ‘exposition’:
geom.c:146: warning: incompatible implicit declaration of
built-in function ‘fabs’
geom.c: In function ‘extends’:
geom.c:206: warning: incompatible implicit declaration of
geom.c: In function ‘shape’:
geom.c:232: warning: incompatible implicit declaration of
built-in function ‘atan’
geom.c:236: warning: incompatible implicit declaration of
built-in function ‘sin’
geom.c:237: warning: incompatible implicit declaration of
built-in function ‘cos’
directory
directory
directory
directory
directory
before ‘CELL’
local_proto.h:140: error: expected ‘)’ before '
’ token
lipo: can’t figure out the architecture type of: /var/folder
s/wc/2dv9njw93k3bfyy5ppkw022h0000gn/T//ccESKY4a.out
make: *** [OBJ.x86_64-apple-darwin12.2.0/geom.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
(Tue Feb 26 09:40:18 2013) Command finished (3 sec)
Your help is much appreciated!
Sincerely,
Robert Brown
All messages comes from compiler informing you haven’t installed standard librarires. This is however the issue of g.extension, which do not work well with Apple systems. Please contact grass dev team how to resolve this issue
regards
Jarek
Thank you.
I am thinking about trying to re-compile GRASS from source code and see if it will resolve the issue. Also, I found some documentation on using python to acquire add-ons with the g.extension manager.
Sincerely,
-robert brown
Michael
C. Michael Barton
USA
Please advise,
-Robert Brown
Dear Sir,
Compiling…
directory
directory
directory
directory
directory
before ‘CELL’
directory
directory
directory
directory
directory
before ‘CELL’
’ token
Sincerely,
Robert Brown
regards
Jarek
grass-user mailing list
