I'd
uninstalled everything related with QGIS, GRASS, GDAL, GMT, etc, >and
installed again from OSGeo4W.
At t
he final stages of OSGeo4W installation, I get the same >curl_mime_init
error with crssync.exe, but referring to gdal301.dll >(image attached).
Are you installing OSGeo4W stack with the exp/testing tick activated? It
looks like as you're installing gdal-dev/gdal301.dll according to the
screenshot.
Then it could be that some library mixing/mismatch may happen.
Try to install a fresh OSGeo4W in normal mode only for winGRASS 7.8.1, then
try to start winGRASS.
In the windows Explorer, search in c:\windows for curl and report back if
you find some curl binary there.
gdal-dev was because I was also installing QGIS 3.10. But without QGIS 3.10 and gdal-dev, I get the same gdal300.dll error in GRASS 7.8.1.
The search for curl in c:\windows shows many results (please see images attached). I start to believe that this can be some local mismatch or conflict with a past installation of some other software that used curl and gdal.
Thank you very much for your help!
Best regards,
Pedro
Helmut Kudrnovsky <hellik@web.de> escreveu no dia sábado, 16/11/2019 à(s) 16:45:
I’d
At t
looks like as you’re installing gdal-dev/gdal301.dll according to the
screenshot.
checking here:
QGIS version 3.10.0-A Coruña
Compiled against Qt 5.11.2
Compiled against GDAL/OGR 3.0.2 <=
Compiled against GEOS 3.8.0-CAPI-1.13.1
Compiled against SQLite 3.29.0
PostgreSQL Client Version 11.5
3.10.0 is now available in OSGeo4W without the need to install gdal-dev
attached). I start to believe >that
some other software that used curl >and gdal
yes it looks like that.
are you using windows 10, right? windows 10 ships curl since about 1 year or
so [1].
I compared your explorer search results here with mine on a windows 10 box.
I’m using nightly builds (qgis-rel-dev), and this one needs gdal-dev.
QGIS code revision 1ffa829539
Compiled against GDAL/OGR 3.1.0dev
Running against GDAL/OGR 3.1.0dev
