latest gr7 trunk build --with-geos is failing in lib/vector/diglib/
with:
[...]linux-gnu/include -o OBJ.i686-pc-linux-gnu/allocation.o -c allocation.c
In file included from allocation.c:21:
/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include/grass/Vect.h:474: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include/grass/Vect.h:475: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include/grass/Vect.h:476: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include/grass/Vect.h:477: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/usr/local/src/grass/svn/trunk/dist.i686-pc-linux-gnu/include/grass/Vect.h:478: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
make: *** [OBJ.i686-pc-linux-gnu/allocation.o] Error 1
include/Vect.h:474 is just after
#ifdef HAVE_GEOS
not sure what's wrong with that.
(libgeos-dev ver 2.2.3-3)
thanks,
Hamish
