[GRASS-dev] Grass7 - Trunk Install from svn question
I was trying to install grass7.0 through svn so I could do some testing and see some of the future development. I had no errors after typing in make, but when I make install I get the following:
root@silver:/usr/local/src/grass_trunk# make install
echo /usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70
/usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70 make[1]: Entering directory `/usr/local/src/grass_trunk' test -d /usr/local/grass-7.0.svn || mkdir -p -m 755 /usr/local/grass-7.0.svn
test -d || mkdir -p -m 755 sed -e "s#^GISBASE.*#GISBASE=/usr/local/grass-7.0.svn#" /usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70.sh > /grass70.sh
sed -e 's#^gisbase = ".*"#gisbase = "/usr/local/grass-7.0.svn"#' /usr/local/src/grass_trunk/bin.x86_64-unknown-linux-gnu/grass70 > /grass70
chmod a+x /grass70
tar cBCf /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu - . | tar xBCf /usr/local/grass-7.0.svn - 2>/dev/null sed 's#'/usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu'#'/usr/local/grass-7.0.svn'#g' /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/fontcap > /usr/local/grass-7.0.svn/etc/fontcap
/usr/bin/install -c config.status /usr/local/grass-7.0.svn/config.status
chmod -R a+rX /usr/local/grass-7.0.svn 2>/dev/null
tar cBf - gem/skeleton | tar xBCf /usr/local/grass-7.0.svn/etc - 2>/dev/null
/usr/bin/install -c gem/gem70 2>/dev/null
make[1]: [real-install] Error 1 (ignored)
make[1]: Leaving directory `/usr/local/src/grass_trunk'
I can not seem to get the install made, any pointers on this one.
Casey
p.s Thanks to the user and dev groups for helping out with all previous questions.
p.p.s. I have really enjoyed using GRASS since the move away from tcl-tk towards wx-python. The interface is far more user friendly and I hope it will appeal to other GIS users out there.
On Tue, Feb 9, 2010 at 12:48 AM, Casey Vandenberg
/grass70.sh
chmod a+x /grass70
"Amusingly", I have opened a similar ticket in the same moment:
http://trac.osgeo.org/grass/ticket/916
Hint for now: no need to install GRASS, you can use it right away
from the compile directory (bin.ARCH/grass70).
