Hi all!
Here is the ninth report of my GSoC project - PyQt based GUI of GRASS automatically generated from XML. For screenshots and other stuff see its wiki: https://trac.osgeo.org/grass/wiki/GSoC/2016/PyQtGUI
What did you get done this week?
New widget: dbtable
I had finally ordered tabs. Required tab is the first one and Optional tab the last one. And if widget has defined guisection, it is now prior to Required.
I had fixed problems with spinboxes. They now allow you to input number greater than 100 and also negative numbers.
Was created first version of sizepolicy. Dialog width and height still depends on content volume, but now just till some limit. After that, the tab gets sliders to scroll.
What do you plan on doing next week?
- Finish things with sizepolicy, clear little bit the code, there are still some widgets which I plan to design better way
Are you blocked on anything?
- I was really blocked on the sizepolicy for a while. I’m talking 'bout it with my mentor and it seems that it will be okay in a while.
Have a nice weekend,
Ondrej
