[GRASS-dev] GSoC: Basic cartography suite in GRASS - Week 10
below is my tenth week report.
Best regards,
Adam
Wiki page: https://trac.osgeo.org/grass/wiki/GSoC/2016/BasicCartographySuiteInGRASS
Week 10, July, 25 - July, 29
  1. What did you get done this week?
    I fixed a bug in d.legend module 1
    I worked on d.legend.vect module. I implemented the vector legend for GUI and d.mon.
    I designed some symbols for area and line vector maps.
  2. What do you plan on doing next week?
    I will continue work on vector legend.
  3. Are you blocked on anything?
    No.
Adam,
On 31/07/16 20:50, Adam Laža wrote:
Best regards,
Adam
Wiki page:
I fixed a bug in d.legend module [1]
GUI and d.mon.
Great work on the cartography front !!
Another idea for the vector legend: add a frequency histogram next to the legend to see how many objects are in each class. A bit like the histogram feature of the raster legend for continuous data (would be nice to have that for categorized data as well).
Just to keep you busy :wink:
Moritz
On Mon, Aug 1, 2016 at 4:34 AM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
Adam,
Best regards,
Adam
Wiki page:
GUI and d.mon.
I suggest to create an enhancement ticket for that because we won't
get to it in this GSoC and this nice idea could get lost.
BTW, I committed the first version of the vector legend, so you can
test it in trunk. You still have to run:
g.extension d.legend.vect
We will move d.legend.vect later into trunk.
Best,
Anna
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
Adam,
Best regards,
Adam
Wiki page:
GUI and d.mon.
I haven't been able to get it to work, neither in the wxGUI nor with a d.mon wx monitor. Is there a short howto somewhere ?
Moritz
On Mon, Aug 8, 2016 at 11:04 AM, Moritz Lennert
Adam,
Best regards,
Adam
Wiki page:
GUI and d.mon.
histogram
that
What exactly is the problem? Have you installed d.legend.vect from addons?
Moritz
It works for me in the wxGUI (grass trunk r69093M).
Did you install the add-on? It works if you also have the add-on installed :slight_smile:
2016-08-08 12:04 GMT-03:00 Moritz Lennert <mlennert@club.worldonline.be>:
Adam,
Best regards,
Adam
Wiki page:
    GUI and d.mon.
I suggest to create an enhancement ticket for that because we won’t
I haven’t been able to get it to work, neither in the wxGUI nor with a d.mon wx monitor. Is there a short howto somewhere ?
Moritz
I have the addon installed in r69064.
Trying to launch it from the wxGUI console I get:
"Command 'd.legend.vect' not yet implemented in the WxGUI. Try adding it as a command layer instead."
I display a local mapset copy of the hospitals file from the NC dataset:
d.vect map=myhospitals@user1 type=point,line,boundary,area,face fill_color=red width=1 icon=basic/cross3
I then add d.legend.vect as a command layer without arguments, and I get the "Rendering..." info in the map display indicating rendering half-way through, the "operation busy"-wheel (don't know if there is an official name for this) turning, but nothing happening. No error message in the wx console or in the terminal.
When I display the same map in the wx0 monitor via the terminal and then launch d.legend.vect in the same terminal I get
d.legend.vect
ERROR: No legend file defined.
GRASS_INFO_WARNING(8082,1): Unsupported command d.legend.vect.
GRASS_INFO_END(8082,1)
Moritz
<mailto:mlennert@club.worldonline.be>>:
        <mailto:mlennert@club.worldonline.be>> wrote:
            Adam,
                Best regards,
                Adam
                Wiki page:
                <https://trac.osgeo.org/grass/wiki/GSoC/2016/BasicCartographySuiteInGRASS&gt;
                vector legend for
                GUI and d.mon.
            the histogram
            nice to have that
    Moritz
    grass-dev@lists.osgeo.org <mailto:grass-dev@lists.osgeo.org>
    <http://lists.osgeo.org/mailman/listinfo/grass-dev&gt;
On Mon, Aug 8, 2016 at 11:25 AM, Moritz Lennert
Added support in GUI since 69085:
https://trac.osgeo.org/grass/changeset/69085
or in the terminal.
d.legend.vect
Moritz
            Adam,
                Best regards,
                Adam
                Wiki page:
                vector legend for
                GUI and d.mon.
            the histogram
            nice to have that
won't
can
    Moritz
With r69104 it works great, thanks !
Moritz
