below is my second week report.
Best regards,
Adam
Wiki page: https://trac.osgeo.org/grass/wiki/GSoC/2016/BasicCartographySuiteInGRASS
Week 2, May, 30 - June, 3
- What did you get done this week?
I worked on the module d.grid.
I worked on the module d.grid. I work on the ticket #30171 and fixed some bugs.
I worked on the module d.barscale.
I solved the ticket #30162 and added option for barscale units.
I worked on the module d.legend.
I started to solve tickets related with d.legend. I’ve already added option for legend title3, now I work on legend labels and ticks4.
I worked on GUI/Workspace
I started to solve ticket #23695 and to integrate map elements size and position into workspace. I made a draft of XML structure that should be saved into workspace .gxw file. I started to extend class WriteWorkspaceFile() so map elements will be saved into workspace file too.
What do you plan on doing next week?
I will work further on the module d.legend. I will add more options for labels and values. I will add options for background and border.
I will work on workspace. I want to finish class for writing into workspace file and start working on reading class. -
Are you blocked on anything?
Not really. This week I spent more time at the university that I had expected but I will work during week-end so it should be OK.
