[GRASS-dev] GSOC project proposal
On Mon, Mar 9, 2015 at 6:32 PM, sarthak agarwal <sarthak0415@gmail.com>
wrote:
Dear Sir/Madam,
Myself Sarthak currently working under Dr. KS Rajan as a research student
in Spatial Informatics Lab, IIIT hyderabad . I am currently working in
spatial databases by optimizing the performance of mongoDb for spatial
databases. Previously i have worked on Billboard placement optimization
problem considering the spatial ,temporal and traffic features.
I am interested in working with grass org under the project "New
easy-to-use command line interface for GRASS GIS*". *The problem looks
interesting to me. I am familiar with the technologies needed for this
project.As i have already worked in c++ and python .
this sounds good. You should find some enhancement or bug in GRASS GIS bug
tracker [1] and implement or fix before the application evaluation it to
show level of you proficiency [2, 3].
For example an enhancement ticket #1204 related to invoking GRASS. The wish
is to start grass7 command with a wxGUI workspace file as a parameter [4].
Another option is to continue in implementing of related #2579, enhancement
to provide command line parameter to execute modules. However, the big
issue there is more the discussion about the interface rather then the
implementation itself which is partially done already.
More challenging option is to implement some part of the GSoC project, e.g.
for rasters or for PostGIS vectors. This is of course highly related task
but it can be tricky and what you need is something which is working well
before the application evaluation. More smaller tasks might a better idea.
To understand how projections (coordinate systems) work in GRASS GIS (see
below), it might be advantageous for you to implement r3.proj module which
would project 3D rasters from one GRASS Location to another. r.proj module
is in C but for start r3.proj module could be in Python and would use
r.proj in the background (similar idea can be ussed for GRASS imagery
groups and temporal datasets which also don't have their "proj" module).
Further, you could try to write r3.in.proj module which would import 3D
raster data in one projection to GRASS Database with another projection
(see source code of r.in.proj). See below for more resources on this topic.
Writing tests for related things such as #2579, or modules r.in.proj,
v.in.proj or the other modules mentioned below might be quite good
introduction to the topic but to show your skill you might want to combine
it with some other task which would involve actual coding.
However, you can explore the open issues on GRASS GIS bug tracker yourself.
Just keep in mind that this GSoC project would be in Python, so the thing
you select be in Python.
In any case, start with compiling GRASS GIS from source code from
Subversion repository [6].
[1] https://trac.osgeo.org/grass/query
[2]
http://wiki.osgeo.org/wiki/Google_Summer_of_Code_Recommendations_for_Students
[3] http://lists.osgeo.org/pipermail/soc/2015-March/002908.html
[4] https://trac.osgeo.org/grass/ticket/1204
[5] http://trac.osgeo.org/grass/ticket/2579
[6] http://trac.osgeo.org/grass/wiki/GSoC/2015#Tipsforstudents
Can you please provide me with some more literature and links to
understand the underlying concept behind the problem and a direction to
solve it.
Start with running GRASS GIS and playing with data in different projections
in case you are not familiar with GRASS GIS already. Read through the
related manual page [7] and/or tutorials online on getting your data into
GRASS Database.
Definitively read the code from various projects and other things linked in
the GSoC idea [8]. Go through the modules related to importing, linking,
exporting and projecting data, some of them are linked below. Look also at
how GRASS GIS can connect to PostGIS [9].
[7] http://grass.osgeo.org/grass70/manuals/helptext.html
[8]
http://trac.osgeo.org/grass/wiki/GSoC/2015#Neweasy-to-usecommandlineinterfaceforGRASSGIS
[9] http://grasswiki.osgeo.org/wiki/PostGIS
Related modules:
http://grass.osgeo.org/grass70/manuals/r.in.gdal.html
http://grass.osgeo.org/grass70/manuals/v.in.ogr.html
http://grass.osgeo.org/grass70/manuals/addons/r.in.proj.html
http://grass.osgeo.org/grass70/manuals/addons/v.in.proj.html
http://grass.osgeo.org/grass70/manuals/r.proj.html
http://grass.osgeo.org/grass70/manuals/v.proj.html
http://grass.osgeo.org/grass70/manuals/r.external.html
http://grass.osgeo.org/grass70/manuals/v.external.html
Source code for r.in.proj and v.in.proj:
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.in.proj
https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.in.proj
Also I want to know whether someone is already committed to this Project or
not?
No, at least nobody wrote to the mailing list.
Best,
Vaclav
Sarthak Agarwal
Btech and Ms by research in Spatial Informatics
International Institute Of Information Technology ,Hyderabad
On Wed, Mar 11, 2015 at 11:36 AM, sarthak agarwal <sarthak0415@gmail.com> wrote:
I have used Grass directly installing from the ppa … I was trying to compile it from the source and i’m getting error .Below is the error.log content.
GRASS GIS 7.0.1svn r64826 compilation log
Note that for development you will need trunk, not release branch.
Errors in:
/home/sarthak/grass-7.0.svn/display/d.path
/home/sarthak/grass-7.0.svn/display/d.vect
/home/sarthak/grass-7.0.svn/vector/v.neighbors
/home/sarthak/grass-7.0.svn/ps/ps.map
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
What compilation guide have you used? What it is saying when you do what it wants?
Can you please suggest me a way to solve it. Also i was looking for r.in.proj’ folder in the source code but couldn’t find it . It was there on the link you send but not on the svn repo. Should i directly copy the files from there to the local repo.
These two modules are in addons. Compare the SVN repo with the Trac URLs and you will find how to get them.
Please, stay on mailing list.
